Home > Td5 > TD5 harmonic damper |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17373 |
My 2002 Disco has the original still at 203,000 miles.
15th Jan 2019 6:35pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5166 |
What's a harmonic damper? ( I am researching TD5s now) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
15th Jan 2019 8:46pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5698 |
Rubber bottom pulley.
15th Jan 2019 9:03pm |
Mentioned in the end of this post.
https://www.defender2.net/forum/topic65328.html |
15th Jan 2019 9:04pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2760 |
Yes l was involved in that thread and was going to change it as a service item until l found out that the part is £400 plus fitting.
Now l want to know if l really need to change it. |
15th Jan 2019 9:45pm |
Explanation was for Procta’s question.
But understand your question, I did 186thou in my previous Td5 without any probs and it always chirped. Don’t all Td5s chirp? |
15th Jan 2019 9:49pm |
A chirp when you stop the engine can indicate a worn harmonic damper.
But it’s only what l have read. |
15th Jan 2019 11:09pm |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
Our Td5 also chirps regularly but the damper is still OK. Turner engineering has them for £145.
J |
16th Jan 2019 4:20am |
vulcanfreak Member Since: 05 Sep 2010 Location: suffolk Posts: 77 |
I have just had the same dilemma, Mine chirped on switch off, for other reasons i took out grill, intercooler and radiator, removed belt and inspected HD as best I could (there was no play in it at all and the rubber looked as new).So I just replaced belt, both idlers and tensioner and now chirp has gone.
16th Jan 2019 3:56pm |
