Home > Td5 > TD5 harmonic damper
lightning
TD5 harmonic damper
Should l replace this item?
As my 2004 110 TD5 is at 106,000 miles. I think l posted on here before about it, and l read that it can fail completely causing some damage.
The engine does “chirp” when you shut it off but always has done. The thing is, the part from LR is about £400 and not something l think l could fit myself.
Is there any way to check whether it’s still serviceable?
My local LR specialist didn’t seem too concerned about replacing it, when l asked them. They thought it was “fine, as they rattle when worn out”
Post #751504 15th Jan 2019 6:30pm
My 2002 Disco has the original still at 203,000 miles.
Post #751509 15th Jan 2019 6:35pm
Procta
What's a harmonic damper? ( I am researching TD5s now) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #751534 15th Jan 2019 8:46pm
landy andy
Rubber bottom pulley. Thumbs Up
Post #751537 15th Jan 2019 9:03pm
landy andy
Mentioned in the end of this post.
https://www.defender2.net/forum/topic65328.html
Post #751538 15th Jan 2019 9:04pm
lightning
Yes l was involved in that thread and was going to change it as a service item until l found out that the part is £400 plus fitting.
Now l want to know if l really need to change it.
Post #751562 15th Jan 2019 9:45pm
landy andy
Explanation was for Procta’s question.
But understand your question, I did 186thou in my previous Td5 without any probs and it always chirped.
Don’t all Td5s chirp?
Post #751564 15th Jan 2019 9:49pm
lightning
A chirp when you stop the engine can indicate a worn harmonic damper.
But it’s only what l have read.
Post #751583 15th Jan 2019 11:09pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Our Td5 also chirps regularly but the damper is still OK. Turner engineering has them for £145.
J
Post #751593 16th Jan 2019 4:20am
vulcanfreak
2006 Defender 90 Td5 Silver LE Zambezi Silver
I have just had the same dilemma, Mine chirped on switch off, for other reasons i took out grill, intercooler and radiator, removed belt and inspected HD as best I could (there was no play in it at all and the rubber looked as new).So I just replaced belt, both idlers and tensioner and now chirp has gone.
Post #751714 16th Jan 2019 3:56pm
