Home > Technical > Td5 Disco canbus.
grafty99
Td5 Disco canbus.
This isn't as off topic as the title might suggest.
I've been given a Disco 2 instrument cluster and have been researching the wiring diagrams to see what would be involved to run them in a defender.
Luckily most of the functions are as per the defender (would have to run a disco 2 map to get the temperature gauge to function correctly)
However some of the functions are canbus controlled, well in fact just 3 of the ones you'd need for a defender.
That's the left and right direction indicator and the trailer indicator warning light. I haven't taken the cluster apart yet to see if it would be possible to drive the LEDs via resistors.
I think it would be awesome to use Arduino or similar to control the canbus functions as there is also a built in speaker which would allow for a light on warning chime etc.
So if anyone could shed some light on how I would go about finding the can protocol out and emulating it I would be very grateful Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #751152 14th Jan 2019 8:10am
I'm sure someone who knows more will be along soon, but I have to say that i thought the only use of CanBus on a Disco 2 was for the communications between the engine ECU and the the auto transmission ECU, and the manual transmission D2 has no CanBus at all. I am very surprised indeed if any of the instrument pack was CanBus.
I understtod that this was the reason that the engine ECU is different between manual and auto versions - the auto version having the CanBus interface and the manual version not having it.
Post #751161 14th Jan 2019 10:03am
Jontd5
Ireland
99% sure there's no canbus in the D2 dash pack - should be handy enough get indicator warning lights sorted - if it's any help I can post a link for a D2 wiring diagram and connector layout - have them for a Td5 defender too if needed
Post #751164 14th Jan 2019 10:12am
grafty99
From the D2 electrical library,
Quote:
The BCU is connected using the serial data bus from pin C0661-1 on an SK wire, via header C0293 LHD/C0292 RHD, to the instrument pack pin
C0233-16.
1990 Vogue SE
Post #751165 14th Jan 2019 10:13am
Jontd5
Ireland
And yes there's a built in speaker on the back of the D2 instruments - tho the chimes might be bcu controlled - the D2 wiring system is actually very simple
Post #751167 14th Jan 2019 10:15am
grafty99
Thank you Jontd5 I have the defender layout diagram for the connectors but only the pin numbers for the D2 so that would be most useful Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #751168 14th Jan 2019 10:16am
Jontd5
Ireland
https://drive.google.com/folderview?id=0B2...jN4LTVkdVU
That's all my D2 and defender stuff, the fusebox and bcu work together to control indicators in a D2 - there's no replaceable flasher unit - there is a two relays in the fuse box , one for left and other right.
What you are trying has been done before I think - so should be possible
Post #751169 14th Jan 2019 10:27am
The Disco2 Electrical Library wrote:
The direction indicators and hazard warning lamp operation is controlled by the Body Control Unit (BCU), Intelligent Driver Module (IDM) and two electronic relays in the passenger compartment fusebox. The IDM and the relays are are an integral part of the passenger compartment fusebox and cannot be serviced individually.
The direction indicator circuit uses the serial data bus between the BCU, IDM and the instrument pack for flasher and hazard request and operation.
The BCU then sends a signal on an SK wire from pin C0661-1, via header C0293 LHD/C0292 RHD, to the IDM in the passenger compartment fusebox. The SK wire is the serial data bus between the BCU, IDM and the instrument pack. The signal is received by the IDM and interpreted as a request for LH or RH flasher operation. The IDM grants an earth path for the coil of the LH or RH direction indicator relay. The coil is energised by the feed from fuse 14 in the engine compartment fusebox, closing the relay contacts.
The control of these indicators is indeed a setrial bus, however I think it is a proprietary bus and not CanBus. Certainly the wiring on the vehicle does not conform to ISO 11898 (it is a single wire system rather than TP for starters) and I don't imagine that it is packet based.
I have never seen a spec for this interface and i suspect that the only way to find out how it works would be to stick a logic analyser on it and see. Then of course there's the problem of how to emulate the BCU/IDM end of it. It is probably easier, all things considered, to modify the instrument pack to work in a more defenderish (ie prehistoric) manner!
Post #751170 14th Jan 2019 10:28am
grafty99
Thanks Blackwolf,
This is what I thought, not really what I wanted to do but as you say. Probably the easiest route Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #751171 14th Jan 2019 10:38am
grafty99
Jontd5 wrote:
https://drive.google.com/folderview?id=0B2cczYinyiWGWmQyTjN4LTVkdVU
Thanks Jon, I'll have a browse Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #751172 14th Jan 2019 10:39am
dorsetsmith
C0233-16.
these are driven by body control unit
Exclamation body control unit have to be match to ECM Exclamation Banging Head
Post #751175 14th Jan 2019 11:13am
grafty99
Decided to go for the KISS approach.
Cut the PCB tracks and soldered direct to the SMD LED.
Got the trailer indicator light working so far....
1990 Vogue SE
Post #751204 14th Jan 2019 3:11pm
grafty99
All working, and switches 12v+ to suit the defender loom Thumbs Up
1990 Vogue SE
Post #751209 14th Jan 2019 3:41pm
dorsetsmith
glad you chose that approach. Rolling with laughter Bow down
Post #751218 14th Jan 2019 4:09pm
Co1
Innovative stuff! Looking forward to seeing it fitted.
Post #751265 14th Jan 2019 6:51pm
