Home > In Car Electronics > Issue with new single din stereo
Millso
I am replacing the OEM stereo in my 2008 TDCi and i am struggling to get the new unit to power on. The loom in the vehicle has the two IOS connector format and the new head unit has a harness that accepts the iso connectors. Do i need some sort of converter or could it be possible that the IOS connectors are wired differently and need re-wiring to connect up the right ones? Before anyone says it, the wiring colours vary on both sides of this connection, so not as easy as just matching the colours.
Any help much appreciated!
Post #749299 5th Jan 2019 12:33am
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
Assuming u get the connector onto your headunit, did u plug in the red cable which for power.
Post #749301 5th Jan 2019 12:51am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Yellow and red can be switched, however that's for constant power after the ignition is off ( to keep the settings on the radio ) and it's dependant on model/make of vehicle
My first thought would be to check fuses.
If they are fine , then fit the original unit back in and see if it powers up, if so, the fault is with the new unit, if not, we'll try something else
Post #749312 5th Jan 2019 8:26am
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
If you have a plug in adapter the Connects 2 version didn't work for me - pins in the wrong place
http://www.caraudiodirect.co.uk/ct20lr04-h...ry-iv-2010
However the Autoleads one is fine
http://caraudiosecurity.com/pc2-117-4-land...ss-adaptor
I recommend buying from MudStuff
https://www.mudstuff.co.uk/products/audio-...pters.html Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #749476 5th Jan 2019 9:19pm
You do not need any wiring adaptor on a 2008 that only applies to 2012> models.
The Defender 2007 - 2012 DIN ISO male plug lay out is the market standard, I would imagine it's the new HU side that is the issue.
Mine plugged in straight away with no modifications every time.
I would swap the pins on the new HU side (female) to match rather than the LR male plugs.
But first I would plug it in and try it, so long as Earth is not matched to ignition or permanent live.
The HU should only turn on with ignition on, and store settings with ignition off (but not turn on.)
It should not turn on at all with the ignition off, if it does then the ignition and permanent live need swapping.
You can usually with a little patience un-pick the connector pin from its housing and carefully adapt it to fit again in the correct colour orientation and you should be sorted.
Unless someone else has swapped the ignition and perm live over on the LR before which I doubt is the case the LR would be DIN ISO and I would match the new units config to the LR loom config.
It'd also be easier to do this on a bench instead of in the dash.
Also check your manual with your new unit. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #749490 5th Jan 2019 10:10pm
Millso
Hi all,
Thanks very much for all the advice. Managed to swap around the wiring on the ISO connector and she sprung to life. Now to upgrade the speaker system!
Post #750502 11th Jan 2019 9:17am
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
What speakers are you looking at? I am soon going to be doing the same upgrade so interested in any recommendations. Sweatysock
110 CSW TDCI (Puma) 2007
Post #751310 14th Jan 2019 9:44pm
Millso
Just ordered Focal 100 KRS components for the front and Focal 100 AC coaxials for the rear. Will eventually stick an active sub in. Don't need crazy power, so not planning a full multi-channel amp job.
Post #751377 15th Jan 2019 8:52am
