Home > In Car Electronics > Issue with new single din stereo |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 |
Assuming u get the connector onto your headunit, did u plug in the red cable which for power.
5th Jan 2019 12:51am |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
Yellow and red can be switched, however that's for constant power after the ignition is off ( to keep the settings on the radio ) and it's dependant on model/make of vehicle
My first thought would be to check fuses. If they are fine , then fit the original unit back in and see if it powers up, if so, the fault is with the new unit, if not, we'll try something else |
5th Jan 2019 8:26am |
Stu_XS Member Since: 22 Jul 2018 Location: Hampshire Posts: 86 |
If you have a plug in adapter the Connects 2 version didn't work for me - pins in the wrong place
http://www.caraudiodirect.co.uk/ct20lr04-h...ry-iv-2010 However the Autoleads one is fine http://caraudiosecurity.com/pc2-117-4-land...ss-adaptor I recommend buying from MudStuff https://www.mudstuff.co.uk/products/audio-...pters.html Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
5th Jan 2019 9:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20367 |
You do not need any wiring adaptor on a 2008 that only applies to 2012> models.
The Defender 2007 - 2012 DIN ISO male plug lay out is the market standard, I would imagine it's the new HU side that is the issue. Mine plugged in straight away with no modifications every time. I would swap the pins on the new HU side (female) to match rather than the LR male plugs. But first I would plug it in and try it, so long as Earth is not matched to ignition or permanent live. The HU should only turn on with ignition on, and store settings with ignition off (but not turn on.) It should not turn on at all with the ignition off, if it does then the ignition and permanent live need swapping. You can usually with a little patience un-pick the connector pin from its housing and carefully adapt it to fit again in the correct colour orientation and you should be sorted. Unless someone else has swapped the ignition and perm live over on the LR before which I doubt is the case the LR would be DIN ISO and I would match the new units config to the LR loom config. It'd also be easier to do this on a bench instead of in the dash. Also check your manual with your new unit. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
5th Jan 2019 10:10pm |
Millso Member Since: 13 Jun 2018 Location: West Berkshire Posts: 3 |
Hi all,
Thanks very much for all the advice. Managed to swap around the wiring on the ISO connector and she sprung to life. Now to upgrade the speaker system! |
11th Jan 2019 9:17am |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 |
What speakers are you looking at? I am soon going to be doing the same upgrade so interested in any recommendations. Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
14th Jan 2019 9:44pm |
Just ordered Focal 100 KRS components for the front and Focal 100 AC coaxials for the rear. Will eventually stick an active sub in. Don't need crazy power, so not planning a full multi-channel amp job.
15th Jan 2019 8:52am |
