Home > Puma (Tdci) > Rust..
Grockle
Rust..
..ing under the bottom corners of the windscreen rubber,check yours,have booked it in again ! 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #74141 4th Jun 2011 8:59am
Zagato
THEY DON'T SEAL THEM FROM NEW!
So water just sits under the rubber! A morning spent with window sealant (get the sticky stuff!) is VERY advisable or get your local fitter to do it for about �50. It stops corrosion and leaks and you can replace any cracking rubbers at the same time Thumbs Up
I replaced the cracking window rubbers on my 4 year old TD5 and discovered the frame had rotted right through Crying or Very sad If any damage is done to the paint work when the window was fitted at the factory it just starts rotting from the get go! You only see it when you take out the rubber. If you discover your frame is badly rotten it's not the end of the world. As with all things Defender it can be easily unbolted and replaced Thumbs Up
Sealant can be got from here Thumbs Up http://www.frost.co.uk/automotive-windscre...ealer.html
Tricky, messy, fiddly job by the way for the practically challenged...some areas are hard to reach and fiddly to get into (under the very bottom of the front window rubber for instance...�50 for someone to do it for you is money well spent.
Post #74158 4th Jun 2011 9:29am
Grockle
Z,it's only 30 months old ! 2.4 90 XS
Post #74189 4th Jun 2011 11:21am
Zagato
I know it's disappointing but ultimately a new frame isn't too much of a hassle to sort and if they treat the rust properly rather than just covering it with new top coat paint each time it might be OK - push for a NEW frame, they will need to take the window out to do a proper job and it's likely you will only go back with the same problem in a few months time so it would be better for them to do the right thing and change the frame Thumbs Up
Post #74192 4th Jun 2011 11:32am
dgardel
Italy
I put a lot of waxoyl inside the bulkhead anywhere, under the seals also.......
So I'm hoping that will be sufficient........
Still not cracking seal yet ...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #74202 4th Jun 2011 1:07pm
Scallops
Australia
Heya Grock! Did the dealers pick this up when they did their "annual corrosion inspection", or was it down to your own diligence?
Post #74934 8th Jun 2011 11:55pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Pardon my ignorance, but are you talking about the bulkhead or the front window frame?
The bulkhead is steel so it can rust, but as far as I can see the window frame does seem to be made of steel nor iron(looks like some sort of alloy?).
Post #74946 9th Jun 2011 8:59am
Zagato
Ofourdan I thought the same as it is so soft. I hand drilled mine to put the snorkel on and it was so soft I was convinced it was alloy of some sort but then thought it couldn't be if some are rusting and my TD5 one was definitely steel as it rotted before my eye's Sad
Either way I am going to pick up a spare one for the future Thumbs Up along with other spares and panels if they ever come up cheap....
Post #74983 9th Jun 2011 1:06pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Oh the irony....... Mr. Green
 Jon - 110 td5 [sold]. Currently Defenderless.
Post #74987 9th Jun 2011 1:19pm
o4dn
Just try with a magnet, it's definitely not steel Confused Anyway, alloys can corrode as well, but it's not rust, it's another form of corrosion.
Post #74991 9th Jun 2011 1:22pm
Happyoldgit
The screen frame itself is cast alloy. Steve.
http://forums.lr4x4.com
Post #74992 9th Jun 2011 1:26pm
Zagato
Thats really good news Very Happy another improvement over my 01 TD5 - didn't need to seal the front window but can't hurt. One less rust spot to worry about Thumbs Up Wonder when they brought that in!
Post #74995 9th Jun 2011 1:40pm
Happyoldgit
I don't recall any of the standard Defender style Land Rover windscreen frames that have owned or worked on been made of anything else. Steve.
Post #74996 9th Jun 2011 1:47pm
bob neville
Corroded windscreen frame is one item on a long list of corroded/rusted parts being looked at by my dealer next week when mine is in for it's 2 year service.
Bob
Post #74997 9th Jun 2011 1:49pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
A teeny weeny bit off topic, but have a look at this :
http://www.popsci.com/scitech/article/2004...g-aluminum ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #75003 9th Jun 2011 4:19pm
