![]() | Home > Puma (Tdci) > Rust.. |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
THEY DON'T SEAL THEM FROM NEW!
So water just sits under the rubber! A morning spent with window sealant (get the sticky stuff!) is VERY advisable or get your local fitter to do it for about £50. It stops corrosion and leaks and you can replace any cracking rubbers at the same time ![]() I replaced the cracking window rubbers on my 4 year old TD5 and discovered the frame had rotted right through ![]() ![]() Sealant can be got from here ![]() Tricky, messy, fiddly job by the way for the practically challenged...some areas are hard to reach and fiddly to get into (under the very bottom of the front window rubber for instance...£50 for someone to do it for you is money well spent. |
Z,it's only 30 months old ! 2.4 90 XS
I know it's disappointing but ultimately a new frame isn't too much of a hassle to sort and if they treat the rust properly rather than just covering it with new top coat paint each time it might be OK - push for a NEW frame, they will need to take the window out to do a proper job and it's likely you will only go back with the same problem in a few months time so it would be better for them to do the right thing and change the frame
I put a lot of waxoyl inside the bulkhead anywhere, under the seals also.......
So I'm hoping that will be sufficient........ Still not cracking seal yet ...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 ![]() ![]() |
Heya Grock! Did the dealers pick this up when they did their "annual corrosion inspection", or was it down to your own diligence?
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 551 ![]() ![]() ![]() |
Pardon my ignorance, but are you talking about the bulkhead or the front window frame?
The bulkhead is steel so it can rust, but as far as I can see the window frame does seem to be made of steel nor iron(looks like some sort of alloy?). |
Ofourdan I thought the same as it is so soft. I hand drilled mine to put the snorkel on and it was so soft I was convinced it was alloy of some sort but then thought it couldn't be if some are rusting and my TD5 one was definitely steel as it rotted before my eye's
![]() Either way I am going to pick up a spare one for the future ![]() |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Oh the irony.......
Just try with a magnet, it's definitely not steel ![]() |
The screen frame itself is cast alloy. Steve.
Thats really good news
I don't recall any of the standard Defender style Land Rover windscreen frames that have owned or worked on been made of anything else. Steve.
Corroded windscreen frame is one item on a long list of corroded/rusted parts being looked at by my dealer next week when mine is in for it's 2 year service.
Bob |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
A teeny weeny bit off topic, but have a look at this :
http://www.popsci.com/scitech/article/2004...g-aluminum ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
