Home > Td5 > TD5 Driver Demand
Page 1 of 5 12345>
TJ101
TD5 Driver Demand
Picked up a base for a new project 2004/5 Bog spec 90 Td5, Very clean, well maintained
First Issue
On the drive home, after 20 miles, engine dies and mil light on,, only got tick over, no throttle response, so recovery job home Shocked
All test's and system scans point to the throttle unit,, so new genuine one ordered
Spoke to vendor, and it would seam, he has the same issue, back in August, and also fitted a new gen unit, 90's now done about 900 miles since
Fitted new unit today, and now have throttle response, BUT, a bad flat spot/hesantance , which struggles to drive through, even with light or heavy throttle load ? which was not there on the first 20 mile on old unit
Fitted the old (August ?) unit, and its back to driver demand fault, no throttle response
So ideas ?? Modul plug ? Loom, back to ECU ?
It due out tomorrow night, as recovery for the Exeter Trail !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #748981 3rd Jan 2019 9:10pm
Could be a break in the throttle cable (sorry... "driver demand") cable.
If you've got a nanocom (and I assume other devices read the same data) there are 2 or 3 signal wires coming off of the pedal (Depending on it's age... early ones were 2 track, later 3 track), the nanocom should read the voltage off of them... 0-5v on one, 5-0v on the other (depending on where the pedal is in its range of movement..ie, foot OFF the pedal... tickover... one track will show 0v, other will show 5v (And on the 3 track system, I'm not sure what the 3rd one shows, between 0 and 5v but I don;t know which way)).. the ECU then sorts it out and gives a relative throttle position for the engine.
anyway.... maybe one of these are duff? on a separate note... wifes suzuki vitara, 2.0D from 2003... had a similar thing; had 3 or 4 complete pedal assy's changed over the years until I kicked up a fuss at the dealers, and suddenly a "repair" harness appeared from Japan. apparently there was a break/fault/Geishi doll stuck in the vehicle wiring harness causing the fault.
Could be a break in the Td5 loom (or a Brummie eating a pasty)...
Post #748996 3rd Jan 2019 9:41pm
lightning
Oil in the ECU, wiring loom?
I am guessing the injector harness has been replaced. Is there any oil showing at the ECU red plug?
Post #749004 3rd Jan 2019 9:59pm
landy andy
Loom from pedal to ECU. I’ve done a few of them.
Post #749016 3rd Jan 2019 10:12pm
mk1collector
Check for oil in ecu plug and unplug the MAF and drive around to see if the power comes back. Ray
My build thread
Post #749031 3rd Jan 2019 10:31pm
TJ101
Thanks all Very Happy
I am thinking loom, the "flat spot/hesantance" is about one third throttle , so am suspecting that wire ? will check them all back to the ECU for continuity tomorrow morning
Not sure why, the unit fitted in August failed ?? it certainly does not work, or give the figures you quote Jamie !!
Symptoms aren't the "oil on injector loom" lighting . all Driver Demands , plus the odd AC, and Tacho drive ! but i did check the loom into ECU for oil, as i sat beside the road, Shocked as first thought !!
I presume you just make up a new loom Andy ? 7 core trailer cable ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #749036 3rd Jan 2019 10:39pm
landy andy
Yes. Just used trailer wire as you say. Not a bad job to do, as long as you can keep warm enough to feel your fingers.
Post #749039 3rd Jan 2019 10:43pm
jst
As before, I wouldn't bother looking for wire break, just replace all with multi core wire. Now have backup for tomorrow so soft top available, home 1900, ring if require it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #749085 4th Jan 2019 7:48am
bankz5152
I would change the Crank Sensor (genuine only) and the MAP sensor (gen only). Both can cause the issues you describe. Just because the throttle input seems off doesnt always mean it is the thottle itself.
Post #749095 4th Jan 2019 9:15am
TJ101
Well, Fingers crossed sorted
Replaced pedal socket and loom,, all good to go now,,
Question is ? why 2 pedals in 6 months , the August one certainly does not work, have the feeling the loom may have been the problem back then ?
But would the loom "burn" out the august unit ? As it was fitted by previous owner ? can only speculate
Thanks for the input guys California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #749110 4th Jan 2019 11:39am
landy andy
I can only assume that the damaged loom puts electrical spike, or voltage the wrong way into the pedal potentiometer.
They can be a long on going problem, one I fixed was a problem over a year and initially only occurred when puddles had been driven through.
Bloody quick work done there. Well done, which I could get my arse in gear to sort my Defender out.
Post #749113 4th Jan 2019 12:02pm
excossack
Is this pedal loom available as a separate part? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #749125 4th Jan 2019 12:45pm
TJ101
No,, Part of the engine loom,, so the dealer says,, Plugs on the bay of E
It had to be sorted by today,, Recovery duties this evening !
I did say fingers crossed !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #749131 4th Jan 2019 12:59pm
landy andy
Buying the plug must make it a bit easier and save a bit of time. Will remember that for next time. I’ve always cut the loom at both ends and reused plug and 6” of loom. Much prefer your method.
Post #749132 4th Jan 2019 1:02pm
TJ101 wrote:
Question is ? why 2 pedals in 6 months , the August one certainly does not work ...
Britpart ?
Post #749134 4th Jan 2019 1:04pm
Page 1 of 5 12345>
