![]() | Home > Puma (Tdci) > Rear step has fallen off |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
My rear step fell off today
![]() Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Yep, I had one pull out on a previous vehicle. You'll need to remove the old rivnuts from step (you'll have to grip the inserts while undoing the bolts). Fit new rivnut inserts into the X member and secure step by bolts into new inserts. Steve.
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
I was told by independent garage that these steps are like autumn leaves - they all fall off when time comes
![]() www.yahodeville.com |
there is a service bulletin regarding the rear step mounting,contact your dealer 2.4 90 XS
It's mainly due to the fact that in comparison to earlier models post 300Tdi rear X members are so thin they might as well be made of cheese. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
I nut and bolted my step, was a buggar to do but alot more secure.
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
I do the same with mine after a caress doing by other car. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
![]() 1968 1/32 scale Britains 109 Pick up. |
Cheers Grockle its got to go back for the 3rd attempt at the PO22 recall soon so i will throw it at them to look at, new rivnuts is not going to work, needs a plate on the inside the holes are ![]() Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Grockle, did yours go back for this? My rear step wobbles. It supports my weight but at 110kg who knows for how long! Out of warranty, and with Lookers on board, the prospect of phoning them fills me with antipathy let alone taking it in for something essentially cosmetic. Any idea what the LR fix is? Some papier-maché? |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 ![]() ![]() ![]() |
I did this to mine, had to cut and bend a spanner to fit into the cross member to hold the bolt to tighten ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5078 ![]() ![]() ![]() |
Mine went in and was replaced/fixed under warrantly about 2 years ago. Its been an issue for a while!! Mike |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
What is the LR fix under warranty, I wonder how they resolve the problem?
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 557 ![]() ![]() ![]() |
I think mine is on its way out, I can't be bothered with a warranty claim for that and would rather replace it before someone gets hurt, I am considering something like that:
http://www.paddockspares.com/pp/DEFENDER/A...nised.html Anyone's tried that? |
