Home > Puma (Tdci) > Rear step has fallen off
noworries4x4
My rear step fell off today Embarassed not that bothered as i have never ever used it, but bit worried about the two big holes left as both the rivnuts came out with the step and bolts, any ideas how to put it back as i said the rivnuts have pulled right out, dont know how this has happened as i said i have never folded it down If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #74760 7th Jun 2011 9:40pm
Happyoldgit
Yep, I had one pull out on a previous vehicle. You'll need to remove the old rivnuts from step (you'll have to grip the inserts while undoing the bolts). Fit new rivnut inserts into the X member and secure step by bolts into new inserts. Steve.
http://forums.lr4x4.com
Post #74765 7th Jun 2011 10:17pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
I was told by independent garage that these steps are like autumn leaves - they all fall off when time comes Very Happy Janusz
www.yahodeville.com
Post #74773 8th Jun 2011 6:18am
Zagato
I saw a step on a year old motor that had pulled the cross-member metal down around the fixing points as though there should have been a washer (or bigger washer/ spreader plate!) behind it to support it more. Are the Riv Nuts giving way or is it the metal distorting?
Post #74775 8th Jun 2011 6:32am
Grockle
there is a service bulletin regarding the rear step mounting,contact your dealer 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #74779 8th Jun 2011 7:04am
Happyoldgit
It's mainly due to the fact that in comparison to earlier models post 300Tdi rear X members are so thin they might as well be made of cheese. Steve.
Post #74780 8th Jun 2011 7:23am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
I nut and bolted my step, was a buggar to do but alot more secure.
Post #74803 8th Jun 2011 11:56am
Eduardo
I do the same with mine after a caress doing by other car.
Cheers Eduardo
Post #74807 8th Jun 2011 12:20pm
Grockle
Whistle 2.4 90 XS
Post #74831 8th Jun 2011 3:55pm
noworries4x4
Cheers Grockle its got to go back for the 3rd attempt at the PO22 recall soon so i will throw it at them to look at, new rivnuts is not going to work, needs a plate on the inside the holes are Censored If everything is under control you are not going fast enough.
No Worries 4X4
Post #74891 8th Jun 2011 8:04pm
110SEB
Grockle wrote:
Whistle
Grockle, did yours go back for this? My rear step wobbles. It supports my weight but at 110kg who knows for how long!
Out of warranty, and with Lookers on board, the prospect of phoning them fills me with antipathy let alone taking it in for something essentially cosmetic. Any idea what the LR fix is? Some papier-maché?
Post #74894 8th Jun 2011 8:10pm
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I did this to mine, had to cut and bend a spanner to fit into the cross member to hold the bolt to tighten Laughing
Post #74914 8th Jun 2011 9:03pm
mse
110SEB wrote:
Grockle wrote:
Whistle
Mine went in and was replaced/fixed under warrantly about 2 years ago.
Its been an issue for a while!! Mike
Post #74929 8th Jun 2011 10:26pm
Zagato
What is the LR fix under warranty, I wonder how they resolve the problem?
Post #74943 9th Jun 2011 7:04am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I think mine is on its way out, I can't be bothered with a warranty claim for that and would rather replace it before someone gets hurt, I am considering something like that:
http://www.paddockspares.com/pp/DEFENDER/A...nised.html
Anyone's tried that?
Post #75952 15th Jun 2011 10:16am
