Home > Td5 > Defender TD5 Clock |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
I am sure there is a recess in the plastic bezel that you can pry it off with. Be aware that the plastic pushrods that do the adjustment are only held in by the bezel and easily drop out when dismantling. 02' 110 TD5 Double Cab Rebuild Thread
27th Dec 2018 4:11pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 501 |
Thanks Steve Paul.
1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
27th Dec 2018 6:38pm |
Jontd5 Member Since: 09 Dec 2018 Location: Laois Posts: 39 |
Yeah I fitted that cheap clock - the main reason I picked that one was it was cheap if my attempt to feed it from alternator didn't work and also it was reasonably close in looks to the factory clocks. It works no problems at all, fitting wire to alternator is a bit awkward but worth it |
28th Dec 2018 7:39am |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
How long have you had it in there now? Is it holding up?? Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
28th Dec 2018 12:02pm |
About 3/4 weeks and all perfect
28th Dec 2018 12:23pm |
Great! Regards
28th Dec 2018 2:23pm |
izack98 Member Since: 25 Sep 2016 Location: Vancouver Posts: 26 |
Just reviving this old thread as I have just replaced my dash lights with LED.
I was able to get the clock apart, clean it and get it working. I found that when reinserting it, if I tightened the ring that holds it in too tight it would stop working. I tightened it just enough to hold it and it works fine. rallysteve are you able to post a link or a part # for the LED lights that you used inside the clock? I'd like to pick some up and swap out the ones that are in there. |
9th Jan 2021 11:35pm |
