Home > Maintenance & Modifications > Removing rear trailing arms
excossack
Got new bushes on order for the arms. I was thinking to remove the arms, leave the car on the ground, in gear/ hand brake on and chock the wheels.
Remove the nut for the arm at the chassis end, then remove the bolt at the axle end and replace bushes. Install new arms, move to the other side.
Does this seem a sensible approach? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #746730 21st Dec 2018 11:20am
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
I think i would want some axle stands/ wooden blocks under the chassis/ rear cross member too. When the the arm is off one side of the axle it'll make the vehicle less stable. It would still be attached to the other arm and the A frame so it's unlikely to drop on you but i wouldn't crawl underneath with no chassis support.
Post #746741 21st Dec 2018 12:47pm
excossack
Good thought on the axle stands. (just in case moment) 1999 Defender TD5 110
Regards
John M0VAZ
Post #746745 21st Dec 2018 1:37pm
jst
Chock 3 wheels. Work on rear unchocked wheel. Undo three three chassis bolts holding dognut Bush. Then undo axle bolt, 22mm, drift out axle bolt, lever out arm downwards, rotate wheel as required to move axle slightly, pull out chassis end. Then remove Bush from chassis end of arm. Only downside to this is undoing large nut without impact tools. Change bushes and refit. Axle stands and removing wheels not required. It can't fall, suspension holds vehicle up. A frame will keep rear axle sufficiently in place.
May need ratchet strap to pull back together on fitting.
Fitting dognut Bush first to arm means your not trying to locate and put nut on at same time. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746762 21st Dec 2018 2:56pm
excossack
Your plan was similar to mine and might even break out the Makita impact gun 1999 Defender TD5 110
Regards
John M0VAZ
Post #746763 21st Dec 2018 3:07pm
jst
Similar yes. The same no. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746794 21st Dec 2018 7:45pm
mermade
Post #747702 28th Dec 2018 10:41am
excossack
I did ponder polybush but went to Gen LR ones, this was based on the fact the bushes have lasted nearly 20years(assuming they have not bee changed) 1999 Defender TD5 110
Regards
John M0VAZ
Post #747714 28th Dec 2018 1:13pm
excossack
One side done. Just missing the torque figures for the three nuts/bolts that hold the chassis end bush in place. The other bolts are 176nm according to the Haynes manual 1999 Defender TD5 110
Regards
John M0VAZ
Post #747715 28th Dec 2018 1:15pm
rallysteve
Workshop manual shows the wrong torque for the bushes to chassis. I cant remember if they are M8 or M10 but tighten them up to 23Nm or 45Nm respectively.
Post #747717 28th Dec 2018 1:26pm
excossack
Cheers Steve. The old bolts where 17mm heads, the new ones are 17mm nut and 13mm bolt with built in washer/flange 1999 Defender TD5 110
Regards
John M0VAZ
Post #747720 28th Dec 2018 1:32pm
rallysteve
Ah yes, M10 it is then Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #747731 28th Dec 2018 2:02pm
excossack
Thanks Steve. Both arms done. And one arm done twice after i noticed i had put a washer axle side rather then 30mm nut side at the chassis end.
As i had to disturb the nylocks am i best to replace? Either way all re-torqued to correct settings 1999 Defender TD5 110
Regards
John M0VAZ
Post #747750 28th Dec 2018 4:15pm
excossack
Since doing the rear arms the car has developed an annoying squeak which sounds like its in the steering column/dash area. On rocking the car I can hear a squeak from the rear end...Sounds like a job for the weekend. 1999 Defender TD5 110
Regards
John M0VAZ
Post #748951 3rd Jan 2019 6:16pm
