![]() | Home > Puma (Tdci) > Diesel leak n/s of engine |
Phid Member Since: 25 May 2018 Location: Dorset Posts: 85 ![]() ![]() |
Probably not connected, but sometimes when I start the car it doesn’t run for more than a second. Then I start it again and it’s fine. Seems to drive ok - no obvious change.
Have a look at U tube video below
fuel manifold to injector pipe nuts lose ![]() fuel Pressure re Lief valve leaking A ![]() fuel Pressure sender leaking B ![]() fuel high presser pump leaking n/s of the engine at rad end down lower ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Last edited by dorsetsmith on 9th Dec 2018 7:38pm. Edited 7 times in total |
Thank you
These engines are new to me so excuse my lack of knowledge. Is this accessible? I would have thought it near the top of the engine but it’s clean up there. |
from this you have a small fuel Leak losing fuel from Syston on start up it needs build presser for engine fire up |
Thanks for the pictures- much appreciated. Given leak seems to be lower down I think the last one is most likely. And it could be the starting issue is linked. I will have a good hunt around - probably have to be next weekend now.
Thanks for the info. |
That’s really useful thanks
Where is the pump physically located - is that on the n/s of the engine? |
yes on N/s
Thanks again
I’ve had a good search around. Top of the engine is clean - it seems to coming from the bottom/side of the fuel pump. It is difficult to see exactly where due to access. I can’t really see much from the bottom of the vehicle and the top is obscured by all of the pipe work.
It won’t start at all now which I assume is due to the lack of fuel pressure. After trying to start there is a small puddle of diesel on the floor so it’s coming out at a fair rate. Any more tips before I submit to the professionals? Thanks |
As its your fuel pump leaking only thing i can think of fuel line connectors and VCV valve
I don’t think it’s the VCV - you can see that quite easily from above - right?
It is quite a bit lower down - either bottom of pump, which you can’t see, or something lower. Is there anything lower that could leak fuel? |
Not sure if connected but in the summer the fuel rail pressure relief valve was changed. Possibly the suction control valve was also changed. I wonder if my issues relate to that?
fuel temp sender is the only other thing on the fuel pump
![]() Click image to enlarge 1. fuel spill return to the pump 4. VCV Last edited by dorsetsmith on 16th Dec 2018 5:31pm. Edited 1 time in total |
