Home > My Defender > What Did You Do In Your Defender Today |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 |
How does it affect handling? I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
10th Dec 2018 7:54am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 |
New LED spots done 👍🏼
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
10th Dec 2018 8:14am |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Got any pictures from before?? Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
10th Dec 2018 10:38am |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 |
I drove it. Bliss.
(Been on hols for the last two and a half weeks, I've been pining ) Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
10th Dec 2018 3:30pm |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 |
I took it to the menders on Saturday morning because the transfer box was leaking. As a temp job the fluid was drained, thread removed and then refitted with a compound of some sort, then refilled. I then took it to Wycliffe College at Stonehouse (100 mile round trip) on Saturday afternoon to watch my daughter play hockey. It was fine, no leaks afterwards even after hitting 75 on the motorway (not for long, mind). 👍
10th Dec 2018 3:53pm |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 |
Fitted genuine perspex light guards, got 25% discount at local stealers while ordering other parts.
The ones I purchased with the LED's were starting to cloud over and for the cost, the 4 years was well worth it (have saved the lights from stones a couple of times). Just hope the genuine ones work as well and last longer. The 'goldfish eye bulge' is also gone... Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
11th Dec 2018 9:35am |
That's a great idea. Saw them on a defender at my mechanics shop.
Ill be looking out for them myself. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
11th Dec 2018 10:12am |
Any chance of a link?? Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
11th Dec 2018 10:18am |
Sorry no link, purchased from LR Stellenbosch, just under ZAR800
Part # LSTC7561 Seen copies, without the lines on ebay for £35-40, genuine closer to £60+ Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
11th Dec 2018 11:27am |
Wow, ok, well better £380 for new lights I guess.
Cheers anyway. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
11th Dec 2018 11:34am |
Maris Widgeon Member Since: 11 Dec 2013 Location: Cotswolds Posts: 216 |
Had a set fitted to one of my old Land Rover 90s and they are great. Make sure you liberally cover the screws with anti seize compound on the screws,otherwise when your headlight bulb goes you may have trouble getting them undone.
I found this out at an awkward moment whilst on holiday and ended up having to pull the plastic heads off because the riv-nuts just kept turning without undoing. They are tough and practical for protecting the headlights, just my experience which may save you some hassle. Nick. |
11th Dec 2018 6:38pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3689 |
Funny you should ask, but it developed an intermittent wobble at 55ish, nothing too severe but noticeable. Had he pre load checked in swivel housings but that was fine as was everything else on the steering. Tracking was out a touch, but that has been rectified now but still a wobble. I can set cruise at 55 and it will wobble for a couple of minutes, then it’s a smooth as you like for a bit. Then the wobble comes back. If it were the spacers causing it directly I would assume it would happen all the time? I’m thinking the extra leverage is affecting something. Next steps are to remove one spacer at a time and they see if the wobble disappears. Will try and squeeze this in at the weekend. |
11th Dec 2018 7:17pm |
Make sure they're located properly and completely central on hub and wheel.
If that doesn't work....Try getting your wheels re-balanced, people tend to knock inner rim wheel weights off when taking wheels on and off. |
12th Dec 2018 7:45am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17551 |
It cracks me up when people say things like this about spacers! The extra loading on the bearings etc as a result fitting spacers (at least spacers of a reasonable sensible thickness) is less that the effect of a passenger getting in the vehicle, it is never going to make a difference. |
12th Dec 2018 1:19pm |
