![]() | Home > Puma (Tdci) > Self inflicted electrical problem |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6637 ![]() ![]() ![]() |
You have blown the fuse for the immobiliser unit, which is still fitted although you don't have the fob - it controls the interior lights too. I don't know which fuse number it is without referring to the diagrams and I don't have access to them right now (sorry)
interior lights fuse ( 2.4 ) fuse 30
interior lights fuse (2.2 ) fuse 29P both 10 amp |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
Many thanks Martin for the quick reply! So, unexpectedly it was my cack-handedness with the spanner that's at the root of the problem?! Thankfully it sounds like its just a matter of locating the right fuse then...
For reference, attached is the list of fuses in the main box. The immobiliser could be F8 (indicated Alarm on the list), or F6 / F7 in the secondary fuse box (also indicated as Alarm). If anyone know for sure... PS - I love this forum. Got a reply / solution within 15mins of posting. Absolutely awesome! ![]() Click image to enlarge |
Thanks Dorset - I will check that right away. I should have checked the stereo (also on that fuse I believe) - would have been a give-away.
2.2 or 2.4?
Check fuses 6, 7 on a 2.4 or 9 on a 2.2 ![]() ![]() |
Car is a 2.4 ... I checked the fuses: F30 (10A) had blown. F6 and F7 in the secondary box were OK.
I changed the blown fuse, and sure enough the interior lights, dash, clock and radio started working. However... there is still no cranking!! Everything else seems to be OK, just that nothing at all happens when I turn the key to start... Unfortunately I didn't have time to check further, as I had to go out, so will further investigate in the morning. From my limited understanding of electrics, the symptoms point to a relay or ignition switch issue, but I am struggling to connect those possibilities to my previous actions of shorting the internal lights and pulling a few fuses... ![]() Any ideas / insights are - as always - much appreciated! |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 430 ![]() ![]() ![]() |
Might be thinking a little outside the box here, but following from Martins point with the immobiliser fuse blowing, as that's what tells the lights to come on. Have you tried locking and unlocking with the keyfob? Does that work ok? When you switch the ignition on do you get the usual lights on the dash? I'm guessing it's just the starter that's not turning on the final stage of turning the key on.
BenB8man - yup, that is correct - everything seems to be working fine, except the starting on the final turn of the key.
This morning I managed to check the relays: Both Main and Starter relays don't seem* to be working, but intriguingly the fault is on the Load Switch side, not the Coil side. That is - when I energize the relays, I can hear the clicking, but if I measure the continuity across the switching side, it stays at 1 - so the switch isn't closing... Increasingly confused about this.... ![]() * was a quick test - needs to be repeated more thoroughly this afternoon to be sure. |
The immobiliser controls the earth path for the starter relay coil. I still think this is your cause.
Thanks Martin - very useful insight, as I thought the Puma 2.4 immobilizer will allow the car to crank, but not start?! If the immobilizer acts on the starter relay, then one presumes it could well be the cause of my issue ... except that my car is not equipped with an immobiliser (no key fob, and "dumb" key to start)...
Great - tested the Starter and Main relays again, with the help of an extra set of hands to hold the leads in place - and they are both fine.
Back to square one ![]() |
2.4 Puma TDCi ECM controls the earth path for the starter relay coil (VIN date specific )
2.4:
![]() Click image to enlarge The 2.2 is indeed handled by the engine ECU. @redline is your instrument pack working ok - mileage displaying ok and gauges/lights working when you turn the key on? ![]() ![]() |
Martin - yup everything seems normal on the instrument cluster. Trip meter went to zero, but that is all. All other electrics
- radio, windows, dash, interior lights, etc... are working fine. Just checked for fault ECU codes with a basic OBCD scantool, and it shows none... |
