Home > Puma (Tdci) > Self inflicted electrical problem
Page 2 of 4 <1234>
redline
Switzerland
Martin - Just had a look at the schematic you posted - I am assuming ECU Alarm is the immobilizer?
So is it correct to infer that the physical immobilizer unit is there even if car is supposedly not equipped with one?! It would presumably be "de-activated"?
If so, could it still somehow be the cause of my issue?
Post #744191 5th Dec 2018 2:03pm
dorsetsmith
form your and my schematic LRJ made mods in 2.4 07 to 2011 Exclamation back to TD5 AS10 crank wiring Exclamation
Post #744193 5th Dec 2018 2:09pm
Martin
Site Admin
My docs are "VIN 760595 on" but that suggests it's after yours?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #744196 5th Dec 2018 2:23pm
dorsetsmith
will make note on this Thumbs Up
Post #744199 5th Dec 2018 2:29pm
redline
Switzerland
My VIN is 771xxx suggesting that the immobilizer controls the starter relay coil. But again, to my knowledge, my vehicle is not equipped with an immobilizer, unless it is disabled, as I do not have a key fob.
Vehicle is a LHD is that makes a difference.
Post #744200 5th Dec 2018 2:31pm
Martin
Site Admin
The box is fitted anyway as it controls stuff like the interior lights from the door switches.
Plus even with no fobs I'm almost certain the immobiliser is still linked to the ECU and carries out an immobilisation function.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #744205 5th Dec 2018 2:44pm
dorsetsmith
unit is in place but in spider mode if you have no fob
Post #744207 5th Dec 2018 2:54pm
redline
Switzerland
Martin / Dorset - many thanks for the help and clarifications!
I'm assuming the immobilizer is the dreaded Lucas 10AS that I have read so much about on this very forum. Great. Rolling Eyes
So the two questions are now:
1. How do I check if the issue is indeed the immobilizer? Presumably see if it is energizing the starter relay coil (pins 85-86)...
2. How do I reset / fix this? Does it have a separate fuse?
Post #744212 5th Dec 2018 3:15pm
Martin
Site Admin
Do the interior lights come on OK when you open the door(s)?
Have you got the new or old interior lights fitted?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #744218 5th Dec 2018 3:45pm
redline
Switzerland
Martin - yup, once I changed the fuse that had blown (F30 10A) - which you and Doset helpfully pointed me to - interior lights functioning normally on both ON/DOOR.
New lights are fitted (front had been swapped previously, this time added the rear).
Post #744219 5th Dec 2018 3:56pm
redline
Switzerland
Just found this with regards to the Lucas 10AS....! Shocked
1. Electronic Engine Immobiliser (Used on MFI-T16 and 300TDi with EDC engines)
This system is controlled by the Engine Management ECU and the Alarm ECU.
When the vehicle is immobilised, the alarm ECU sends a signal to the EMS ECU
which prevents starting, and until it receives a de-immobilise signal it will not
start.
2. Remote Smart Spider (Used on MFI-T16 and 300TDi without EDC engines)
This system is controlled by the alarm ECU and the Engine immobilisation ECU
(Spider).
The alarm ECU sends a signal to the spider ECU to disable vehicle start, which
then interrupts the starter circuit, fuel pump circuit and ignition coil (If fitted) or
the fuel pump shut off solenoid in the case of the 300TDi engine (without EGR).
NOTE : The vehicle can only be started using the Plip key or the EKA code.
Post #744255 5th Dec 2018 8:24pm
dorsetsmith
https://www.technozen-electronics.co.uk/la...-services/
start by making shore you have + DC supply to you ignition switch and down to the starter relay coil with the switch start position
also make shore you haven't blow more fuse
Post #744264 5th Dec 2018 8:59pm
redline
Switzerland
Right - finally had some time to look at this:
1. Checked all fuses in main and secondary boxes. ALL OK
2. Checked starter relay. I am getting power across pins 85 and 86 (coil side). However I am only getting 7V, NOT 12V ... Not sure if this is normal?! Confused
Dorset - am I correct in assuming that if I am getting power at the starter relay, I don't need to check for power at the ignition?
Post #744468 7th Dec 2018 11:37am
dorsetsmith
Right Checked starter relay again but thing time 86 (coil side) to body work ground, are you getting 12v Question
if you still get 7v check the battery voltage Poz to neg , then check poz to body work ground are you getting 12v ?
Post #744471 7th Dec 2018 11:58am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
7 volts isn't normal. What's your battery voltage?
Post #744472 7th Dec 2018 12:01pm
Page 2 of 4 <1234>
