![]() | Home > Puma (Tdci) > turbo noise help |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5854 ![]() ![]() |
I think you’ve blown the gasket between turbo and exhaust system.
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
Are the hoses OK, seems it is leaking pressure Augusto
Defender 110 TD5 2001 Discovery 4 TDV6 |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
I'd be interested what you find with that. Mine sounds similar when I'm 'pushing on' but is fine during normal driving. I'll have a check of my hoses etc today.
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2205 ![]() ![]() ![]() |
My TD5 (same set up) made the exact same noise yesterday! For about 30 mins when driving then stopped suddenly. I didnt find the cause let me know if you do.
Mine only happened about 2000 - 2500 rpm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
If the turbocharger whistles with increasing speed, the shaft might be damaged or worn out. The whistling noise is caused by the metallic friction. |
Sorry to restart this thread. Did you ever find out the issue?
