Home > In Car Electronics > Interior LED light upgrades |
I did something similar and it works a treat. A strip light above the rear door, mounted at an angle on some little purpose-made brackets: Click image to enlarge Click image to enlarge The result is excellent: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Nov 2018 11:20am |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Oooh the postman's just been!!! Delivered me some goodies!
But... The lights don't look right? Are they correct for my truck, I drive a 2004 td5 xs... These bulbs are for the dash board. I watched a video on changing the lights and the bulbs the guy had looked different... Could have been an older truck mind you.. So before I strip my dash down are these the right bulbs? Click image to enlarge I also got some interior lights. Click image to enlarge And my snow cowl arrived.. £40 on amazon - which didn't arrive, then found on ebay for £22. Click image to enlarge Will upload pics when all fitted 😁 Ps sorry to post over several threads Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
12th Nov 2018 1:41pm |
Most people use the 'New Posts' function so they'll find your post regardless of where it is. By and large, there's no need to duplicate. Darren
12th Nov 2018 2:16pm |
Hi all.
How does one change the clock light? I did the fuel & temp gauge, my pliers were too fat for the speedo, so have to go and get some. I also changed the interior lights. Look forward to hearing from you all. Click image to enlarge Click image to enlarge Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
13th Nov 2018 8:55am |
Been out and got my long nose pliers, lets hope they fit in the hole in the speedo to change the bulbs...
I also got some star shaped Allen keys to try and undo the clock to get to the bulb.. I did notice though, that I got 3 large bulbs left in the kit, I see that 2 go in the speedo - but don't reckon the 3rd large bulb goes in the clock does it? Anyone got any ideas????? Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
13th Nov 2018 12:32pm |
So got it all done. Blew a fuse too, changed that out.
I did pull the clock right out, I saw 2 'clips' 1 either side, did try to pry it apart.. But, didn't want to break it.. So I put it back and left it alone.. Heres the final product. Still don't like the green clock... Click image to enlarge Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html Last edited by Adam17 on 14th Nov 2018 9:49am. Edited 1 time in total |
13th Nov 2018 8:17pm |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 161 |
piccie no worky
14th Nov 2018 6:16am |
Ill sort it now. thanks for the heads up. Regards
14th Nov 2018 9:48am |
Wow. Very effective. Must be a lot brighter. Agreed the clock needs to match.
To be honest not for me but good you have it sorted out. Once I've got these lights mounted and the two si8 lights on the back I'll get some photos up. Mike |
14th Nov 2018 11:26am |
Actually the brightness itself is no different, just the colour.
In regards to the clock, I fount its actually like a one piece, and the clock light is integrated and cant be changed.. Perhaps I need to get a see through blue sheet and cut to size and stick over the clock face lol. Look forward to seeing your pics. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
14th Nov 2018 12:30pm |
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 122 |
I bought these and all working well so far (much brighter interior light):
Haichen Pack of 4 Festoon LED White Car Light 36-41mm, Error Free Led Dome Festoon 4014 12-smd, For Dome, Reading, License Plate Light (36mm) by HaiChen Learn more: https://smile.amazon.co.uk/dp/B07557R1FC/r...OCbDGX65QE Thanks for the suggestions |
1st Apr 2019 8:36pm |
