Home > In Car Electronics > Interior LED light upgrades
Page 2 of 3 <123>
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
Hmmm that sounds like a bit of a worry. Try flipping them around the other way in the holder.. read that in another thread.. circuit might have a diode in it or similar.
Post #737789 31st Oct 2018 12:30pm
JOW240725 wrote:
Further more now lost stereo and clock, so must have blown a fuse? How you blow a fuse changing a bulb is beyond me, but should probably have a look in the light next time.
The interior lights share a fuse with the stereo and clock. The back plate of the interior lights is permanently live and it's very easy to short them out when fitting non-standard bulbs. For this reason, I insulated the fittings on mine with some plasticard to shield the back plates :
 Darren
Post #737791 31st Oct 2018 12:47pm
dgardel
Italy
CarMan wrote:
Love my Nakatanenga ones including brothel mode, but not cheap - of course Thumbs Up
+1 here Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #737969 1st Nov 2018 11:46am
JOW240725
Good idea LRA, thanks. Bow down James
Instagram @suffolk_rovers
Post #737996 1st Nov 2018 1:54pm
Stacey007
Turned mine to red for our trip to Lakes over Halloween (mud Stuff ones LED white or Red) ooh and added a puddle light Smile
Post #738067 1st Nov 2018 8:01pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
[quote="LandRoverAnorak"]I've just fitted three of those festoon LED's from Conrads and they're (literally) brilliant. A very nice warm white light with no low powered glow like the cheap ones that they replaced.
I think I'd like to do the same but with blue.
Can you fine people confirm I have the right bulbs? And size at 36mm? I have measured mine, and I thought it came out at 38mm, but I don't see a 38mm
Look forward to hearing from you Bow down Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #739132 7th Nov 2018 12:05am
Mike_E
you can get 36mm or 39mm festoons. 39's fit.. but 36mm are the originals as far as I know.
mike
Post #739145 7th Nov 2018 7:32am
Adam17
Thanks Mike. Regards
Adam
Loving The Duchess
Post #739219 7th Nov 2018 5:46pm
Mike_E
just checked the festoons from Conrad.. 39mm.
they are a step change from the nasty harsh blue-ish white cheapos from Ebay. Exactly the same colour balance as the original incandescent bulb, just a massive step change in light output.
To be honest these ones have 6 emitters per festoon, they do a 3 emitter version for half the light output and for the front light above the driver it would probably be enough!
not had a chance to try the light bars yet - car only just back after 1.5 weeks in the paint shop and getting a new ignition barrel and lock set fitted
Mike
Post #739276 7th Nov 2018 10:56pm
Adam17
Cheers for the reply.
On another note.. In relation to the lights....
I ordered a Terrafirma snow cowl from amazon... £39.99 bit expensive but I trust amazon and like the money back guarantee..
Anyways it was supposed to arrive on the 5th, so dropped them an email on the 7th letting them know it hadn't arrived, they said they could send one out Monday over night, if I wanted......
Well I'd actually seen the same thing cheaper on another site, so asked for a refund..
Then I looked for it but couldn't remember the site I went on.. So popped do to ebay and found the same Terrafirma snow cowl, even cheaper than the cheap site at 22.99..
Which meant I could buy the lights, and dash lights for less than what I was going to pay for the snow cowl!
BONUS! Thumbs Up Thumbs Up Thumbs Up Regards
Adam
Loving The Duchess
Post #739442 9th Nov 2018 2:57am
Mike_E
Ha, good result.
Also what a coincidence as I just fitted a mudstuff snow cowl last night! I think I've probably paid over the odds though given your eBay find.
Post #739448 9th Nov 2018 6:43am
Adam17
Time will tell.
It says Terrafirma, but I'll update when I see the quality 😉 fi gers crossed though. Bow down Regards
Adam
Loving The Duchess
Post #739545 9th Nov 2018 6:17pm
Mike_E
Just to close this one out.. tried the LED bars last night in the car. the colour balance is great, not harsh at all.
https://www.atenlighting.co.uk/50cm-slim-led-fitting.html
I ordered bright, warm white, 50cm long.
Mounted on the side panels its really bright on the eyes, not really useful when you stand at the back of the car as you are squinting. The light is quite directional too, the LED bars have to be angles down ~45deg towards the floor to get the best use of them.
best option in my opinion - a single 1m long bar mounted above the rear door, 45deg downwards, facing forwards. No shining in the eyes and in conjunction with the LED Festoon bulb its like blackpool illuminations in the back!
I'm mounting the 2-off 50cm ones above the rear door in this fashion over the next week or two.
mike
Post #739976 12th Nov 2018 7:47am
Adam17
Nice. Maybe look at getting one.. the list for the defender just keeps growing, I seem to be getting further away from the goal lol Regards
Adam
Loving The Duchess
Post #740002 12th Nov 2018 11:18am
JOW240725
Also to come back on this from my earlier experience. Fuse replaced (stereo and clock working again) and the interior bulbs are working properly now. The Aten blubs now work properly and are a great bright warm light, not the rather harsh white light I had previously, so now very pleased. Thumbs Up James
Post #740003 12th Nov 2018 11:21am
Page 2 of 3 <123>
