Home > In Car Electronics > Interior LED light upgrades
Page 3 of 3 <123
Mike_E wrote:
best option in my opinion - a single 1m long bar mounted above the rear door, 45deg downwards, facing forwards. No shining in the eyes and in conjunction with the LED Festoon bulb its like blackpool illuminations in the back!
I did something similar and it works a treat. A strip light above the rear door, mounted at an angle on some little purpose-made brackets:
The result is excellent:
 Darren
Post #740018 12th Nov 2018 12:20pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Oooh the postman's just been!!! Delivered me some goodies!
But...
The lights don't look right? Are they correct for my truck, I drive a 2004 td5 xs... These bulbs are for the dash board. I watched a video on changing the lights and the bulbs the guy had looked different... Could have been an older truck mind you..
So before I strip my dash down are these the right bulbs?
I also got some interior lights.
And my snow cowl arrived..
£40 on amazon - which didn't arrive, then found on ebay for £22.
Will upload pics when all fitted 😁
Ps sorry to post over several threads Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #740044 12th Nov 2018 2:41pm
Most people use the 'New Posts' function so they'll find your post regardless of where it is. By and large, there's no need to duplicate. Darren
Post #740052 12th Nov 2018 3:16pm
Procta
I have a mud light fitted to mine, the original light I had was a write off, badly rotten. I will fit on in the back at some point, when I get around to doing a headline job. The only problem I have is, the red light thing is useless. You don't even use it. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #740150 12th Nov 2018 9:33pm
Adam17
Hi all.
How does one change the clock light?
I did the fuel & temp gauge, my pliers were too fat for the speedo, so have to go and get some.
I also changed the interior lights.
Look forward to hearing from you all.
 Regards
Adam
Loving The Duchess
Post #740246 13th Nov 2018 9:55am
Adam17
Been out and got my long nose pliers, lets hope they fit in the hole in the speedo to change the bulbs...
I also got some star shaped Allen keys to try and undo the clock to get to the bulb..
I did notice though, that I got 3 large bulbs left in the kit, I see that 2 go in the speedo - but don't reckon the 3rd large bulb goes in the clock does it?
Anyone got any ideas????? Regards
Adam
Loving The Duchess
Post #740271 13th Nov 2018 1:32pm
Adam17
So got it all done. Blew a fuse too, changed that out.
I did pull the clock right out, I saw 2 'clips' 1 either side, did try to pry it apart.. But, didn't want to break it.. So I put it back and left it alone..
Heres the final product.
Still don't like the green clock...
 Regards
Adam
Loving The Duchess
Post #740364 13th Nov 2018 9:17pm
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
piccie no worky
Post #740440 14th Nov 2018 7:16am
Adam17
Ill sort it now. thanks for the heads up. Regards
Adam
Loving The Duchess
Post #740461 14th Nov 2018 10:48am
Mike_E
Wow. Very effective. Must be a lot brighter. Agreed the clock needs to match.
To be honest not for me but good you have it sorted out.
Once I've got these lights mounted and the two si8 lights on the back I'll get some photos up.
Mike
Post #740473 14th Nov 2018 12:26pm
Adam17
Actually the brightness itself is no different, just the colour.
In regards to the clock, I fount its actually like a one piece, and the clock light is integrated and cant be changed.. Perhaps I need to get a see through blue sheet and cut to size and stick over the clock face lol.
Look forward to seeing your pics. Regards
Adam
Loving The Duchess
Post #740485 14th Nov 2018 1:30pm
newton-tony
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
I bought these and all working well so far (much brighter interior light):
Haichen Pack of 4 Festoon LED White Car Light 36-41mm, Error Free Led Dome Festoon 4014 12-smd, For Dome, Reading, License Plate Light (36mm) by HaiChen
Learn more: https://smile.amazon.co.uk/dp/B07557R1FC/r...OCbDGX65QE
Thanks for the suggestions
Post #766455 1st Apr 2019 9:36pm
Page 3 of 3 <123
