Home > Technical > Heat shield rattle
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Heat shield rattle
Does anyone else have this REALLY annoying heatshield rattle from around the manifold (on Puma)? If so, has anyone been able to fix it? I've inserted some spacers under the shield to lift it away from the manifold area bit still it rattles. I really don't want to be putting it in for a day to have something so minor (yet annoying) to be done.
Ade D300 HSE 110
Post #74012 3rd Jun 2011 4:04pm
Glynparry25
Mine does it- I noticed that the rear securing bolt had worked its way loose (and out). I replaced it and all quiet..... for about a month and then the bolt I put in (and thread locked had also worked its way out!!! Have given up for now (until I fit my de-cat).
Glyn Dog Sheep
Post #74027 3rd Jun 2011 5:40pm
spudfan
Ireland
Mine started rattling like a machine gun one day and I found there were a couple of the retaining bolts loose. Tightened them up and been quiet since. I check them regularly but they stayed tight. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #74040 3rd Jun 2011 7:43pm
Fifth Horseman
I had the same rattle, as in Glyn's case the rear bolt had vanished, this was replaced and then the front of the support bracket broke, after that was replaced those rattles stopped.
see also http://www.defender2.net/forum/post68703.html#68703
Post #74042 3rd Jun 2011 7:53pm
gambit
I have a TD5 and had the same problem. When I had a bit of maintenance work done, a little bit of re-work to the shape cured the problem Smile
Post #74134 4th Jun 2011 8:42am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Yer had it replaced 3 times by LR then got fed up so just took it off !!! 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #74218 4th Jun 2011 3:55pm
nicknick
England 2010 Defender 90 Puma 2.4 CSW Tonga Green
Hi 18Stone , my puma made this noise from the heatshield and your right its proper annoying, the rear most bolt which goes into the manifold had come loose.
The trick is to fit an expansion bolt (not as fancy as it sounds), find a bolt the same thread but 10-15mm
longer than the original, fit a short piece of steel tube (10-15mm) over the bolt and bolt the heatshield back on as normal, this piece of tube allows for movement due to heat expansion but doesnt come loose.
hope this helps. Thumbs Up
Post #74524 6th Jun 2011 8:42pm
18stone
Thanks chaps. I'll have another go at fixing it. D300 HSE 110
Post #74610 7th Jun 2011 9:42am
Can't really hear the heatshield rattling, the noise is drowned out by the rear brakes rattling!
Anyone have a solution to the rattling rear brake 'feature'?
Post #74622 7th Jun 2011 10:16am
18stone
Not sure how old yours is and therefore how old the brake components might be but I had a really loud loose metallic rattling from my rear brakes on a TD5 110. I replaced the pins and, most importantly, the springs, that the pads slide in and out on. Problem solved. If you have a really recent model then I wouldn't expect the springs to have lost their spring though.
The kit was about £3.00 per wheel. D300 HSE 110
Post #74812 8th Jun 2011 1:43pm
Kez
Isle Of Man
Post #75949 15th Jun 2011 10:52am
