Page 1147 of 1378 <123 ... 114611471148 ... 137613771378>
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Today I am Well chuffed! I found the leak in the footwell.
I had to strip out the carpets and bulkhead liner thing, at first it didn't look like there was anything obvious, it all looked sealed... Got my wife to shine a torch into the engine bay in several places and no obvious holes...
So I got the hose on it whilst my wife was looking in the foot well 'found it' she yelled, 'it's pouring through!' she exclaimed.
So I went and had a look, she took over the hose and started showering the windscreen. The water was pouring through 2 holes above the accelerator pedal.
So I got some rtv Sealent that I had left over from when I added slickshift and plugged the holes with that. I'm currently waiting for it to dry so I can put all the liner and carpet back in.. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #739643 10th Nov 2018 11:35am
dorsetsmith
Post #739662 10th Nov 2018 12:51pm
Adam17
I'm not one fir clicking random links..
What is it? [/u] Regards
Adam
Loving The Duchess
Post #739775 11th Nov 2018 1:18am
AJC
blackwolf wrote:
I would imagine that the absence of anything that resembles lubricant would have been a causal factor in the demise of that bearing!
Bearings were greased and fit properly. I can only assume it was a dicky bearing.
Post #739780 11th Nov 2018 7:13am
JOW240725
Adam17 wrote:
I'm not one for clicking random links... What is it? [/u]
Whilst I agree, Dorestsmith is a very well trusted member and the link is JLR guide to water leaks, all 27 pages of it! Well worth a read Thumbs Up James
Instagram @suffolk_rovers
Post #739785 11th Nov 2018 7:58am
Adam17
Thank you.
I meant no offence, just very cautious. Wink Ill give it a read later if I remember. Regards
Adam
Loving The Duchess
Post #740010 12th Nov 2018 10:58am
Adam17
Oooh the postman's just been!!! Delivered me some goodies!
But...
The lights don't look right? Are they correct for my truck, I drive a 2004 td5 xs... These bulbs are for the dash board. I watched a video on changing the lights and the bulbs the guy had looked different... Could have been an older truck mind you..
So before I strip my dash down are these the right bulbs?
I also got some interior lights.
And my snow cowl arrived..
£40 on amazon - which didn't arrive, then found on ebay for £22.
Will upload pics when all fitted 😁 Regards
Adam
Loving The Duchess
Post #740041 12th Nov 2018 1:38pm
G4V JW
LED interior bulbs are wicked, I fitted some 200 lumen halfrauds owns today and the difference is mental Instagram; @gavin_walding
Post #740399 13th Nov 2018 9:21pm
Adam17
Yeh the LED's are great. Very bright..
They're OK for getting in and out the car, but long periods of the blue mess with my eyes lol Rolling with laughter
 Regards
Adam
Loving The Duchess
Post #740468 14th Nov 2018 10:51am
excossack
Fixed the passenger side speaker - turned out to be a duff connection behind the radio.
Replace the high level brake light bulb
Replaced the LED bulb for the temperature gauge
Noticed rear number plate light had gone. On inspection, contacts are corroded so ordered an LED replacement
Oh and replaced both headlight bulbs on the Focus - so a day of not seeing the light - but I am now! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #740661 15th Nov 2018 10:55am
Adam17
ay!, that's a lot of light changing! glad you got it done. Regards
Adam
Loving The Duchess
Post #740665 15th Nov 2018 11:55am
excossack
Certainly was a lot of light! 1999 Defender TD5 110
Regards
John M0VAZ
Post #740671 15th Nov 2018 1:11pm
Ghound
United Kingdom 1999 Defender 110 Td5 SW Alaska White
Fitted a new front bumper to my 110, i much prefer the chunky look, before and after pics.
Post #740795 16th Nov 2018 9:45am
excossack
In an attempt to find the oil leak on the drivers side of the engine, I got some Jizer, a garden sprayer and kettle of boiling water, Mixed the two up and sprayed on the engine. Followed by a hosing and then a wiping over with a cloth. Time will tell.
A bit more progress on the heater mirrors. Wiring into the mirror arms and mirror glass removed (this is a spare set I have)
Cleaned rear window with auto glym glass polish, much better and scrapped a massive bird turd that had dried on the front window. 1999 Defender TD5 110
Regards
John M0VAZ
Post #740849 16th Nov 2018 4:52pm
Pjembe
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Well...About a week ago the dipped beam failed on both headlights. Full beam worked OK so did the side lights. Checked the bulbs, they were fine, checked the fuses, all fine, Did a search on the forum and the wider internet and read about similar problems with othe TDCI Defenders. Went on eBay bought a new headlight switch, dismantled the steering column shroud and plugged that in... nope that didn’t solve the problem, read a bit more, might be the indicator, fullbeam, horn switch, back on eBay....that didn’t sort the problem. I’m now starting to think of all the serious (and expensive) garage costs to get this repaired. Reluctantly I phoned the local independent but they couldn’t fit me in till late next week. Spoke to the main dealer again. Late next week.
Then a thought occurred to me. I have a boomslang loom fitted into my light system. I wonder..... I pulled the relay from the boomslang loom and bridged terminals 2 & 8 and joy of joys the dipped beams worked! A quick rummage in my goody bag for a spare relay and within seconds the problem solved! (It took longer to zip tie the relay back in place than sorting the problem)
So from that experienced; The good - I managed to solve the problem myself without having to fork out to a garage. I’ve learnt from the experience.
The bad - I’ve forked out for two replacements, that I didn’t need to. I’ve been stressing out all week and having to swap cars around all week with my wife so we can get the Defender home before it gets too dark. And that it was such a simple thing to fix, I wish I’d have thought of it earlier.
You live and learn.
Post #740899 17th Nov 2018 12:44am
