Home > My Defender > My truck 😍 πŸ–€ The Duchess πŸ–€ 😍
Page 4 of 17 <123 45 ... 151617>
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
I am on holiday currently, but at home working on the house and my truck..
Today I was tinting..
Removing the old and replacing with a darker tint.
So the boot has the old tint the glass in the back has the new tint
In this pic the back has the new tint and the boot has the old tint.
I have also been a little naughty and put some medium tint on the front windows.
It looks really dark in this pic, but from the inside it's quite light.
Tomorrow will be spent doing the small side windows possibly... (as I don't have enough for the back door - and I'm worried that removing the tint will damage the heat strips further...
Then I'll be trying to locate the water ingress into the driver footwell... Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #739551 9th Nov 2018 5:34pm
Adam17
Oh and I also added a poppy a couple of days ago in remembrance of those fallen for our freedom.
 Regards
Adam
Loving The Duchess
Post #739552 9th Nov 2018 5:36pm
Adam17
Today I am Well chuffed! I found the leak in the footwell.
I had to strip out the carpets and bulkhead liner thing, at first it didn't look like there was anything obvious, it all looked sealed... Got my wife to shine a torch into the engine bay in several places and no obvious holes...
So I got the hose on it whilst my wife was looking in the foot well 'found it' she yelled, 'it's pouring through!' she exclaimed.
So I went and had a look, she took over the hose and started showering the windscreen. The water was pouring through 2 holes above the accelerator pedal.
So I got some rtv Sealent that I had left over from when I added slickshift and plugged the holes with that. I'm currently waiting for it to dry so I can put all the liner and carpet back in..
 Regards
Adam
Loving The Duchess
Post #739644 10th Nov 2018 11:36am
Adam17
So after checking my work I found that it was also leaking from behind the accelerator pedal too.
So I bunged a load of sealant under and around the bottom half, hit it with the heat gun for a little while, and then tried again with the water, this time nothing was getting through... Thankfully!
Hopefully my mats will stay dry now. 😁 Regards
Adam
Loving The Duchess
Post #739669 10th Nov 2018 1:18pm
landy andy
Yep. That’s the ones I mentioned that were leaking on my Td5. Good news
Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Post #739670 10th Nov 2018 1:18pm
Adam17
Thanks bud. 😁 Regards
Adam
Loving The Duchess
Post #739774 11th Nov 2018 1:17am
Adam17
Oooh the postman's just been!!! Delivered me some goodies!
But...
The lights don't look right? Are they correct for my truck, I drive a 2004 td5 xs... These bulbs are for the dash board. I watched a video on changing the lights and the bulbs the guy had looked different... Could have been an older truck mind you..
So before I strip my dash down are these the right bulbs?
I also got some interior lights.
And my snow cowl arrived..
Β£40 on amazon - which didn't arrive, then found on ebay for Β£22.
Will upload pics when all fitted 😁 Regards
Adam
Loving The Duchess
Post #740045 12th Nov 2018 1:42pm
Adam17
*duplicate post deleted* Regards
Adam
Loving The Duchess
Post #740046 12th Nov 2018 1:44pm
Procta
Might be worth everyone doing this too, I will have to do the same with mine at some point. I need a new window screen rubber, so a new heated unit will be going in, but that's next year now.
Great news you found the leak! Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #740143 12th Nov 2018 8:20pm
Adam17
So this morning I decided I was going to try and change the lights in the dash.. I couldn't wait lol.
But I can't seem to work how one changes the clock light?
I did the fuel & temp gauge, my pliers were too fat for the speedo bulbs, so ill have to go and get some today..
I also changed the interior lights, and added my snow cowl.
 Regards
Adam
Loving The Duchess
Post #740249 13th Nov 2018 9:29am
Adam17
Yeh indeed, glad I found the leak. Window rubber is on my list too. Regards
Adam
Loving The Duchess
Post #740272 13th Nov 2018 12:34pm
Adam17
Been out and got my long nose pliers, lets hope they fit in the hole in the speedo to change the bulbs...
I also got some star shaped Allen keys to try and undo the clock to get to the bulb..
I did notice though, that I got 3 large bulbs left in the kit, I see that 2 go in the speedo - but don't reckon the 3rd large bulb goes in the clock does it? ill find out later.. Regards
Adam
Loving The Duchess
Post #740275 13th Nov 2018 12:58pm
Chocolate
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
Hi Adam,
I have done the same as you, replaced all of them except the clock, as I couldn’t find a bulb for it.
Reading other sites they mention taking it apart.
I used a pair of long tweezers for the speedo, fiddly and the bulbs kept breaking the tabs (but I think this was just cheap bulbs)
I ended up buying some better quality ones in the end.
Mad a big difference, much brighter.
Good luck
Wayne, 110XS CSW TD5.
Post #740283 13th Nov 2018 2:48pm
Adam17
Thanks for the reply Wayne. I have a set of the star screw bits, but the adapter is too fat for the access holes at the back of the clock, so today I got some 'allen' star keys today, that will allow me to take the clock apart and see what bulb it takes.. But my kit only has 3 of the larger size bulbs(for the speedo)
We will see how it goes this evening. Ill update as and when. Regards
Adam
Loving The Duchess
Post #740288 13th Nov 2018 3:26pm
Adam17
So got it all done....
Blew a fuse too, as this donut tried changing the polarity with the power on and connected the ends with my long nose pliers.. So changed the fuse out.
I did manage to break a clip off the light, just aswell they sent a spare, must be a common issue..
I also pulled the clock right out, I saw 2 'clips' 1 either side, stuck a pair of tweezers down each one and did try to pry it apart.. It wasn't shifting, & I didn't want to break it.. So I put it back and left it alone..
Heres the final product.
Still don't like the green clock... But no choice.. Big Cry
 Regards
Adam
Loving The Duchess
Post #740362 13th Nov 2018 8:15pm
