Home > Technical > Very hot transmission tunnel, never had it before. |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5829 |
You are, of course, absolutely right. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
18th Oct 2018 10:23am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17450 |
The TDCi handbrake is renowned for issues if the shoes are adjusted too close to the drum. Usually it is a knocking and snagging effect as the shoes pick up the drum in normal driving, especially noticeable at low speeds.
It is always worth have a little more slack on the shoes than you think should be there. If the handbrake applies fully in under five clicks, the adjustment is too tight. |
18th Oct 2018 11:05am |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
I wonder if this is the issue that I have with my juddering under load 🤔 as I stripped the prop shafts off and handbrake. Vibration went for a few miles and now back.
Also have a very hot transmission tunnel/seat box. My handbrake is fully tight at two maybe three clicks at a stretch. I’ll slacken it off and see how I go. Cheers. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
18th Oct 2018 9:55pm |
My transmission tunnel turns in to a radiator if I open the windows. It's so bad that it's cooler to drive with the windows shut in the summer than it is to open them, which is a bit counter intuitive (and sweaty).
19th Oct 2018 7:42pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Mine too !! I found that driving (slowly or quickly ) with the window open caused the transmission tunnel to become VERY warm - but as soon as I closed the window it quickly cooled down again. This happened in all heater settings, recirculation air or with the air vents open or closed ... Keeping the windows closed solved the problem ... it seems that this is probably related to the current 2.2 as I never had the same problem in the 2.4 My hand break is very loose (catching towards the end of travel) so I think that is not applicable to the problem. I have replaced the flooring under the cubby box for the Nackky under cubby and Planner air heater unit, which has no insulating mating so may refit that. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
19th Oct 2018 8:49pm |
Interesting that you say you think it’s a 2.2 problem, because Blackwolf and I both have 2.4s.
But seriously, i never had the problem at all in the 2.2, and remember that it had a very loose handbrake. Also I didn’t have the problem in the current DCPU 2.4, until the output shaft and clutch were replaced. So perhaps the handbrake was over tightened when put back together? Going to take it apart, clean, regrease and reassemble it this week, but slightly looser. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
20th Oct 2018 7:10am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
might just need the adjuster backing off a bit which will save you a load of time and hassle DEFENDER 90 TDCI XS,
20th Oct 2018 9:29am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 499 |
For sure - I follow this trick most of the times. Why use an handbrake? The handbrake is very good for steep hills. There you shall be extra-careful because the car will move if the hill is too steep and it's secured by gear. But it will be no problem to follow and catch it My transmission became more than hand-warm (40++ °C) while the car was new. Now that it is older I enjoy the cold transmission, a far better slight and the lower fuel consumption. |
28th Oct 2018 2:12pm |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 |
Thought I would revive this old thread rather than starting a new one!
I'm intending to adjust my handbrake this evening and have a couple of noddy questions: 1) How best to grease the cable? 2) What should I use? Grease or would PTFE spray be suitable? 3) How does the auto-adjust work? Am I doing something to keep making it tight? Drove ~150 miles last night and the transmission tunnel was roasting. When I slowed down to a near stop I could hear the shoes rubbing 2011 CSW XS 90 |
17th Jun 2021 12:54pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2301 |
Mine gets BOILING on a long journey - it even melted Mrs Hank's make up inside her handbag in the footwell once - she was not impressed.
Genuinely don't think it's the handbrake drum in my instance as I once travelled with an infra-red thermometer to keep tabs on temps just after I rebuilt the transfer box. Transfer box and subassemblies were around 75 degrees... Though I suppose that is pretty warm next to your leg > 110 XS Double Cab |
17th Jun 2021 1:14pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
Have you checked the expander if it is sticking this would cause your problem? Item 29 in the picture Bad news if it is shot as genuine ones cost over £500.00 which is ridiculous for such a small part AEU2734. The trouble is aftermarket expanders do not last very long. Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
17th Jun 2021 2:03pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 486 |
The 2.2 has a DPF in that area which will get very hot especially whilst regenerating |
17th Jun 2021 2:29pm |
Defenders haven't had that type of transmission brake since 200TDI days up to 94MY |
17th Jun 2021 2:31pm |
Highly recommend changing oils to Swepco they make a tremendous difference to running temps and wear and tear. Speak to Mark Ratcliffe at Inspiring Solutions
17th Jun 2021 2:34pm |
