Home > Technical > Help - Indicators have died! |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
I think your blind! Fuse im sure is the same as the brake circuit (shows you there is a problem there) - ill go and check, but im almost sure. This must be old defender!
Update Fused at 31 and 21 according to the wiring diagram - but your right it doesnt show it in the manual, as they are just the hazard switch fuse...have you tried that Mike Last edited by mse on 30th May 2011 9:10am. Edited 1 time in total |
30th May 2011 9:02am |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
Brake lamps F13 no mention of indicators.
LRA on their way! Pom |
30th May 2011 9:07am |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
If its a puma the indicator fuses are under the drivers seat, if they blow straight away again check the bulb holders at the rear are not full of crud and shorting out, Also under dash in other fuse box check it indicator relay has not wiggled out a bit not making contact. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
30th May 2011 9:09am |
Just checked and updated for you - my v8 manual shows it on brake circuit - so i read the wiring diagram for you and the answer is above Mike |
30th May 2011 9:12am |
31 and 21 are hazards not indicators and per my first post the hazards are working fine.
thanks anyway. LRA are only an hour away so will see what they say and report back. cheers Pom |
30th May 2011 9:15am |
Would you like the wiring diagram?? They say hazards but they are wired to indicators It then goes via the hazard switch to header k109 and then to the idicator Mike |
30th May 2011 9:16am |
Click image to enlarge Having said that it could be anything...indicators are over-rated anyway! Mike |
30th May 2011 9:20am |
im just going from the manual!!
30th May 2011 9:21am |
The sheet 2 bits show you the buld - the cut out above is the main circuit from the wiring manual Mike
30th May 2011 9:25am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
as I mentioned some time back, coat the bulb holder and connectors with vasaline to stop corrosion of the contacts happening 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
30th May 2011 9:51am |
LRA are having a look as we speak. IT is a weird fault as the central locking doesnt flash the indicators but when you press the hazards they work!
Will update when its fixed. |
30th May 2011 10:53am |
and the verdict - bloody water in the front indicator!
Will be taking the tip to vaseline all the bulb holders. Big thumbs up for LRA though, 1 hour response, friendly and knew exactly what he was doing. No why cant dealers employ these guys! Pom |
30th May 2011 11:06am |
They would make no money Glad its sorted Mike |
30th May 2011 11:57am |
scottish110 Member Since: 10 Nov 2011 Location: Inverurie Posts: 363 |
I have had the same issue a few weeks ago. Took it to land rover and they said the would have to strip the whole car which would take 2 days and they would be charging me £70 per hour for the electrician !!! There is alot of condensation in my lights so im wondering if this may be the problem after having so much snow laying on the car ? Did you just dry it out and it started working properly again ? thanks |
6th Feb 2013 12:37pm |
