Home > Technical > Joining 1984 fuel tank to Puma gauge
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
Hi all, hoping for some practical advice on sorting out my fuel gauge that isn't quite reading right however.....
I've fitted a puma bulkhead and instruments to my 1984 90 and therefore have an underseat tank and original (1980's) sender. The gauge reads almost right at the top of the scale but shows just under 1/4 at the bottom when the tank is empy.
I've had the sender out and when I move the float get the same range as when its in the tank and burning through the fuel.
Having an accurate gauge is important to me as its a V8 and every extra millimeter showing on the gauge means an extra 400 yrds Rolling Eyes
Ideally, I would like to just fit a puma sender in to my tank however I'm presuming there's a whole host of problems with mounting holes, tank depth etc to work thorugh. Or, can I do something with the original sender to change the resistance so the gauge shows right????
Any advice gratefully recieved Very Happy
Post #733598 8th Oct 2018 1:10pm
geobloke
Could you not fit a puma rear fuel tank and sender? You would have to adjust the mounts, but it should fit fine between the chassis rails.
Post #733599 8th Oct 2018 1:17pm
Martin
Site Admin
What year Puma instruments?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #733601 8th Oct 2018 1:21pm
V8Simon
2007 I think they are.
Post #733602 8th Oct 2018 1:23pm
V8Simon
That's one option I'd not thought about but sounds fairly involved. I'm hoping there's a 'electronic' fix I can do Embarassed
Post #733603 8th Oct 2018 1:25pm
geobloke
Post #733606 8th Oct 2018 1:33pm
Martin
Site Admin
Can you measure the "full" and "empty" resistance of your sender?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #733608 8th Oct 2018 1:35pm
V8Simon
geobloke wrote:
Ok well how about this then;
https://sites.google.com/site/shannonpower...fuel-gauge
Humm that appears to be my problem in the second explanation. I'll have to give it a try and see what happens!
Thanks for sharing
Thumbs Up
Post #733626 8th Oct 2018 3:17pm
V8Simon
I guess so using my multimeter. I'm thinking if I got the same info from a puma sender, I could follow the guide from Geobloke but with a bit more know how?
Post #733627 8th Oct 2018 3:20pm
Martin
Site Admin
2.4 Puma is the same as a Tdi and Td5. Haven't measured a V8 or petrol sender so can't advise without measurements Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #733630 8th Oct 2018 3:26pm
geobloke
Learn something everyday Thumbs Up
Post #733632 8th Oct 2018 3:35pm
V8Simon
So if I can fit a TDi sender in my tank which might be a little easier rather than try the TDCi one, it will be accurate on the gauge??
EBAY here I come..........
Bow down
Post #733798 9th Oct 2018 10:40am
Martin
Site Admin
In theory yes - my side tank sender (1988 TD) works the Puma gauges nicely, same as the rear tank sender (Td5).
However, get a multimeter on your existing one to see what's going on with the Ohms first.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #733799 9th Oct 2018 10:42am
