Home > My Defender > The new workhorse - 300tdi 90 rebuild
Page 3 of 5 <12345>
JOW240725
Great project, nice to see another one being saved! Thumbs Up Bow down James
Instagram @suffolk_rovers
Post #724309 19th Aug 2018 9:17pm
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Thumbs Up Cheers James and Clayton, steadily plodding away Whistle
Lol Procta, It's almost a military-ish operation on this one .... checked everything as it came off, if it was FUBAR it got replaced, then boxed and labelled.... so far the plan is working Shocked
Post #725061 23rd Aug 2018 3:53pm
under_rover
Well September turned out to be a crazy month, but progress has been made none the less Very Happy
Had to treat the old girl to a lot of shiny new things Neutral .... Must be due to the previous owner thinking that an unmolested model means one that did't require any maintainence Whistle
This was the entire amount of oil I emptied out of entire vehicle Shocked and most of that was from us making him top it up from empty on the dipstick to drive it home Rolling with laughter
First up set of shiny new stub axles, the old set had worn due to loose wheel bearings wearing ridges in them
Rebushed, new shocks and springs too
Post #733490 7th Oct 2018 5:43pm
grafty99
Ideal! Thumbs Up
Makes me want to do another one Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #733517 7th Oct 2018 7:32pm
under_rover
Lol....Don't let me lead you astray Twisted Evil ..... might pester you for another set of your demisters for this one if you're getting bored Very Happy Cheers
Laurie
90 rebuild thread - https://www.defender2.net/forum/topic62909.html
Post #733518 7th Oct 2018 7:38pm
grafty99
Never a boring life when you own a Landover! Let me know if/when you need another set Thumbs Up
I think another project might be a divorce level event Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #733528 7th Oct 2018 8:36pm
under_rover
lol.... I'll take you up on that offer Grafty.
Acquired a bargin set of extended studs for the wolf rims
On with the new discs and bearings.... Even the locknuts were knackered after countless tightening using a screwdriver instead of a socket Big Cry
Laurie
Post #733535 7th Oct 2018 9:02pm
L110CDL
Nice progress Thumbs Up but not surprised with the lack of maintenance on it Rolling Eyes Clayton.
Keeper.
Post #733906 9th Oct 2018 7:47pm
Procta
looking good there Thumbs Up yeah mines had some funny people work on mine too. Bent MOT and half arsed jobs, ( barely tightened up pipes on the fuel tank!) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #733912 9th Oct 2018 7:54pm
under_rover
Cheers Clayton & Procta Thumbs Up .... I sort of hunted out an unloved knackered example, made it easier to chuck chunks into the weighing in pile and know I'll not have to keep sorting niggly jobs forever more Whistle
So both diffs rebuilt
Calipers launched into scrap bin, pistons well and truely seized and resisted all know methods to free them off
New calipers, dust shields and the back end is complete Very Happy
Next up front end Thumbs Up Cheers
Laurie
Post #734063 10th Oct 2018 4:59pm
L110CDL
Looking good there, so much better as you can see it's loved at even this point of the build Thumbs Up
I know this is a bit of a long shot, but what did you do with all the matting in the cab under-rover Question Clayton.
Keeper.
Post #734094 10th Oct 2018 7:27pm
under_rover
Without looking in the boxes Clayton I'm not sure what of it if any I kept, were you after anything specific? Cheers
Laurie
Post #734159 11th Oct 2018 6:20am
under_rover
So now Iv'e got my bum in gear and sorted the pics, it's time for a quick update and fast forward through the front axle Very Happy
This axle was in the same delightful state of repair as the rear and so the scrap pile grows Neutral
New swivels, seals, bolts, gaskets fitted and races for the swivel bearings installed
Swivel housings shimmed up, and seals fitted....The stop bolt and top bracket are the right way around now for the eagle eyed amongst you Thumbs Up
Stub axles replaced as they were on a par with the rears, worn through badly adjusted wheel bearings. One had destroyed itself internally too, with nothing left of the thrust washer or needle bearing.
Hub intenals renewed and fresh discs fitted
Calipers, again were in same state as the rears and unsalvagable
Finally back up on 4 wheels Very Happy Very Happy Very Happy
Lastly for this quick post
Panhard rod, steering box and associated linkages, dampers etc fitted and a new chassis loom dragged through
That's all folks, well for now anyway Whistle Cheers
Laurie
Post #734633 14th Oct 2018 9:16am
NickMc
Just in case youve set them up and torqued them with the wrong figures, that’s not a railko bush- theyre the bearing type, Railko has the fibre washer disc Thumbs Up
Post #734647 14th Oct 2018 10:26am
under_rover
Lol NickMc.... you're quite correct, was just this old dinosaur stuck in the terminology of old Whistle , but yes they're all tweeked up correctly and post amended Thumbs Up Cheers
Laurie
Post #734652 14th Oct 2018 10:38am
Page 3 of 5 <12345>
