![]() | Home > My Defender > The new workhorse - 300tdi 90 rebuild |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Great project, nice to see another one being saved!
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 152 ![]() ![]() |
Well September turned out to be a crazy month, but progress has been made none the less
![]() Had to treat the old girl to a lot of shiny new things ![]() ![]() This was the entire amount of oil I emptied out of entire vehicle ![]() ![]() ![]() Click image to enlarge First up set of shiny new stub axles, the old set had worn due to loose wheel bearings wearing ridges in them ![]() Click image to enlarge Rebushed, new shocks and springs too |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
Ideal!
![]() Makes me want to do another one ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Lol....Don't let me lead you astray
![]() ![]() Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
Never a boring life when you own a Landover! Let me know if/when you need another set
![]() I think another project might be a divorce level event ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
lol.... I'll take you up on that offer Grafty.
Acquired a bargin set of extended studs for the wolf rims ![]() Click image to enlarge On with the new discs and bearings.... Even the locknuts were knackered after countless tightening using a screwdriver instead of a socket ![]() ![]() Click image to enlarge Cheers Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10955 ![]() ![]() |
Nice progress
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5264 ![]() ![]() |
looking good there
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Cheers Clayton & Procta
![]() ![]() So both diffs rebuilt ![]() Click image to enlarge Calipers launched into scrap bin, pistons well and truely seized and resisted all know methods to free them off ![]() Click image to enlarge New calipers, dust shields and the back end is complete ![]() ![]() Click image to enlarge Next up front end ![]() Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
Looking good there, so much better as you can see it's loved at even this point of the build
![]() I know this is a bit of a long shot, but what did you do with all the matting in the cab under-rover ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Without looking in the boxes Clayton I'm not sure what of it if any I kept, were you after anything specific? Cheers
So now Iv'e got my bum in gear and sorted the pics, it's time for a quick update and fast forward through the front axle
![]() This axle was in the same delightful state of repair as the rear and so the scrap pile grows ![]() New swivels, seals, bolts, gaskets fitted and races for the swivel bearings installed ![]() Click image to enlarge Swivel housings shimmed up, and seals fitted....The stop bolt and top bracket are the right way around now for the eagle eyed amongst you ![]() ![]() Click image to enlarge Stub axles replaced as they were on a par with the rears, worn through badly adjusted wheel bearings. One had destroyed itself internally too, with nothing left of the thrust washer or needle bearing. ![]() Click image to enlarge Hub intenals renewed and fresh discs fitted ![]() Click image to enlarge Calipers, again were in same state as the rears and unsalvagable ![]() Click image to enlarge Finally back up on 4 wheels ![]() ![]() ![]() ![]() Click image to enlarge Lastly for this quick post Panhard rod, steering box and associated linkages, dampers etc fitted and a new chassis loom dragged through ![]() Click image to enlarge That's all folks, well for now anyway ![]() Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html Last edited by under_rover on 14th Oct 2018 1:10pm. Edited 1 time in total |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Just in case youve set them up and torqued them with the wrong figures, that’s not a railko bush- theyre the bearing type, Railko has the fibre washer disc
Lol NickMc.... you're quite correct, was just this old dinosaur stuck in the terminology of old
