Home > Technical > Uprated exhaust studs
razz
2001 Defender 90 Td5 PU Caledonian Blue
Hello everyone , where do you get the uprated exhaust studs from ? Or should I just go genuine Land Rover ?
Tar
Post #733479 7th Oct 2018 4:03pm
razz
Found some on eBay , wurth unrated for 15 quid , bonus
Post #733482 7th Oct 2018 4:28pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Spot on. Google how to get them out it's all over the internet 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #733493 7th Oct 2018 5:49pm
bankz5152
My method was spraying with plus gas twice daily for a week. Then ran the engine for 15 mins before I tried to remove them, slowly and carefully. None snapped Very Happy Instagram @defender_ventures
Empire Tuning - Agent
Post #733495 7th Oct 2018 5:59pm
razz
Cheers dudes , stud one was easy. Stud two is naughty , will take me time , using a heat gun and spray
Post #733501 7th Oct 2018 6:13pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Might as well reseal that bung while the manifold is off, will save stripping again in the future to cure a coolant leak.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #733512 7th Oct 2018 7:13pm
razz
Sure will fella , good idea is that Thumbs Up
Post #733529 7th Oct 2018 8:37pm
razz
So , while I wait for me new cobalt drill bits and 8mm tap to arrive later this week , I thought i’d try an exhaust stud that had not snapped , put a nut on , welded it into place , left it to cool , sprayed some magic stuff and it snapped off , hardly any force to , so I just gonna spray , spray n spray . Don’t fancy drilling all the studs, but if u have to I’ll have too.
Post #733530 7th Oct 2018 8:42pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I found a useful thing to get snapped studs out was left-handed drill bits. With the drill in reverse they quite often catch and unscrew the stud whilst you are drilling it out. A couple did require a stud extractor but all came out ok in the end.
Word of warning - your local hardware shop will give you funny looks and ask if you want some tartan paint to go with the drill bits but they doe exist. Think mine came from ebay. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #733555 8th Oct 2018 5:43am
razz
All out except the two original snapped ones , they now have a 4mm hole drilled thru , I have a variety of drill bits on the way , including left hand ones . Got a 6.8mm bit coming and a brand new 8mm tap too , just in case
Post #733690 8th Oct 2018 7:22pm
landy andy
With the snapped ones, wind them in, then clean/tap the tread down to the stud, THEN wind them out. That’s how I found it best with the ones I’ve done.
Andy.
Post #733707 8th Oct 2018 8:10pm
NickMc
Is that a dent in the oil filter Whistle and have you got a coolant leak from the top hose? puddle on the top of the water pump housing?
Post #733735 8th Oct 2018 11:07pm
razz
The oil filter is dented to match the panels Thumbs Up and i’ve just changed and bled the cooling system , hence the puddle , but good news , they all out and all threads are clean , except the second in from right of the bottom row , the first five threads are stuffed. But I have plenty of thread past that , so i’ll Get a bolt for that one , next up , get everything off my disco 2 td5 and put on this one as that’s pre-warped and already skimmed
Post #733862 9th Oct 2018 6:18pm
