![]() | Home > Technical > 10mm+ shim wheel spacers? |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
https://www.ebay.com.au/itm/CXRacing-5x6-5...2801960369
Is there anywhere in the UK which sells shim type spacers for the defender? I'd like to run 285 75 16 on some boosts but Blackwolf had pointed out, with 30mm spacers they'll throw mud down the sides my 90 even with gwyn lewis mud flap extensions. I think there's enough thread to safely run 10mm, although 15mm might be pushing it. 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
Found these: 120 inc VAT: http://www.wheelspacers.uk.com/product_inf...amp;typ=LD 1993 200 Tdi 90 CSW
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Fit some Dirt-defenders too. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
Yep, I have those for the rear
![]() 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2206 ![]() ![]() ![]() |
Spacers like that can be dangerous. Fit eider mud flaps.
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 530 ![]() |
If you fit longer wheel studs though they are safer than normal spacers
Yep exactly my thinking, with some 60mm wheel studs ![]() + I already have gwyn lewis mud flap extensions 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
I've also emailed these guys:
https://www.superforma.co.uk/wheel-spacers...pacer.html http://www.rakeway.com/ If anyone else would be interested in some 20mm bolt on or 15mm slip-on (to be used with 60mm studs), let me know 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
With the size of LR tyres and wheel arches, I'm not sure that 10mm is worth the effort. I think I'd struggle to tell the difference
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I don't disagree, in order of my preference:
Ideally i'd like a set of 20mm hub-centric spacers 15-20mm slip on spacer with 60mm studs 10mm slip on spacer with normal studs 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
I was always led to believe that 30mm was the minimum thickness of bolt-on spacers due to the thickness of the LR wheel nuts and the need for there to be enough metal beneath them for adequate strength. Darren
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
The only thing wheel spacers do in my opinion is kill wheel bearings faster
I'm not sure, they make hubcentric 20mm spacers for V8 diesel landcruisers and plenty of high power cars? I guess you have to use some common sense, if you're going to be towing 3.5T regularly or youre going to be loaded down for an expedition, then you don't use spacers at all. My 90 is just a restoration project that'll see light use, maybe some light/medium green lanes. 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1464 ![]() ![]() ![]() |
If want to do 70mph occasionally with wide and heavy 33" mud tyres, that are notoriously hard to balance, then spacers may not be a good idea for that either!
