![]() | Home > Technical > 10mm+ shim wheel spacers? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5854 ![]() ![]() |
20mm off set is a nice amount and would be my preferred. With bigger mud flaps and guards you can keep the sides clean, especially the passenger door handle.
I used to run these wheels which were 20mm ![]() Click image to enlarge |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Received a reply from Superforma:
We would be able to manufacture these wheel spacers in 20mm, although due to the hub on your Defender it would need to be a flat spacer with no outer lip to centre the wheel. This is due to the depth of the lip on your hub. 20mm pair would be £110.00 + VAT per pair and would take upto 10 working days for us to manufacture, they would then be dispatched on a next day courier at a cost of £7.99 + VAT. Total price for one pair including VAT and delivery - £141.59 Anyone else interested in these, if so I might try to arrange a group buy? I do have a few questions that I feel still need answering, will post their reply: Are they steel or aluminum Why do they need to be flat as there are lots of other manufacturers which produce hub centric spacers for the Defender? https://www.ebay.co.uk/itm/Wheel-Spacers-x...3404842998 The price is quite high in comparison to other suppliers, is there a reason for this? How would I pay assuming i’m in agreement on the above? 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
As far as I can tell, I was the first to do a front wheel bearing on my defender at approx 190k miles. It had spacers fitted for at least 120k of that! |
At that price and no outer lip to center wheel, it’s a no from me. With wheel centering lip I’m interested. But if not will just get 30mm spacers.
Andy. |
