![]() | Home > My Defender > here she is |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
Hello everyone , back to the pit at last, and my daughter got us stuck , simply superb indeed
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Looks like you're both having fun
![]() It's great to have a toy that you don't need to rely on for work on Monday. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Cheers fella , I sure is lucky , and it was a fantastic morning , I really must sort out my alternator , when I had a disco 2 td5 , I never had a problem , but on this one , i loose voltage due to driving around in 4ft of water , it does the usual squeaking for many miles after , the disco did not , wonder if I can move it up , hmmmm or get the alternator off my disco n put on to try
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Sorry, who got it stuck? ![]() ![]() ![]() Looks a great day! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10894 ![]() ![]() |
Great your having a good time and thanks for the pic's
Bonjour dudes , I basically only fit britpart to the pit machine , and to be honest it’s all been ok , i’ve had to replace the top hose cos it was mucky , the Brit part one is very flat on the main bend , i’ll give it a go at the next pit play , if it upsets the works , i’ll get a pretty blue one
Ady ![]() Click image to enlarge |
Filled her up with this stuff , then went for a long ride to heat her up , she sits at 89.9 degrees all day long below 45mph , above 45 she slowly starts to heat up , got to 93 degrees when doing over 50 . Thank god it’s got silly tyres on to keep it slow , suppose I should pull the head in case the gasket is failing , or stay under 45 which is easier
New injector harness coming, new filters too , she was running a smidge rough today , bet it’s the
![]() ![]() Click image to enlarge |
You got it in one with the remark of the diesel
so today , the thing came out for a spin , and it went like this , she starts on the button in the garage, but when its time to leave , it just clicks from the solenoid. hmmmmmmmmmm . anyways , a few swear words and we away , so shes gotta new injector harness , air and diesel filter and a bottle of diesel booster from halfords slung in to , do a 15 mile plod to esso and fill her up with premium diesel at 1.49 a litre , i then try to leave and click , click , click. some more swearing and she starts , a quick blast to work and i go underneath , clean the chassis earth and solenoid connections , and hooray , she works every time , afterwork , i drive to jsf norwich to get some magnetec for me engine , cos its not been changed in over a year , on the way there , the indicators pack up , so with some wire wiggling , they work once more , so with magnetec on board , we head head out for some high speed flat out runs ( ha ha ha ) long story shortened , shes now so smooth , up to 60 shes now a million percent better , at 70 the unbalanced muds are rubbish anyway , so several miles covered between 40 -55mph , temps are good , shes smooth , got power too , adjusted boost to give 226kpa , yep , really pleased , will let her cool down and then change the oil , bring on the pit
ady |
Yum yum
Whilst investigating a ticking noise , I have found that the exhaust flexi bit under turbo is split and i’ve got a bust stud , so i’ll pull it apart , get some uprated studs , find somewhere to skim my manifold , get a new down pipe and put it all back together again , oh the joys
The broken stud was so easy to get out , the next one above which was also bust , is being very naughty indeed
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5241 ![]() ![]() |
Asda ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
