Home > My Defender > here she is
Page 9 of 26 <123 ... 8910 ... 242526>
razz
2001 Defender 90 Td5 PU Caledonian Blue
An update , was not going to use the defender till September , but had to use it this week , threw the original screen n bashed the roof back and plated the join , a splash of sealant and she’s back . Will now collect parts and wait to change it
Post #722846 11th Aug 2018 12:26pm
razz
Hello everyone , back to the pit at last, and my daughter got us stuck , simply superb indeed
Post #728059 9th Sep 2018 11:27am
Looks like you're both having fun Very Happy
It's great to have a toy that you don't need to rely on for work on Monday. Darren
Post #728087 9th Sep 2018 1:48pm
razz
Cheers fella , I sure is lucky , and it was a fantastic morning , I really must sort out my alternator , when I had a disco 2 td5 , I never had a problem , but on this one , i loose voltage due to driving around in 4ft of water , it does the usual squeaking for many miles after , the disco did not , wonder if I can move it up , hmmmm or get the alternator off my disco n put on to try
Post #728118 9th Sep 2018 5:57pm
JOW240725
Sorry, who got it stuck? Shocked Rolling with laughter Bow down
Looks a great day! James
Instagram @suffolk_rovers
Post #728148 9th Sep 2018 7:20pm
L110CDL
Great your having a good time and thanks for the pic's Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #728370 10th Sep 2018 7:40pm
razz
Bonjour dudes , I basically only fit britpart to the pit machine , and to be honest it’s all been ok , i’ve had to replace the top hose cos it was mucky , the Brit part one is very flat on the main bend , i’ll give it a go at the next pit play , if it upsets the works , i’ll get a pretty blue one
Ady
Post #731396 26th Sep 2018 6:59pm
razz
Filled her up with this stuff , then went for a long ride to heat her up , she sits at 89.9 degrees all day long below 45mph , above 45 she slowly starts to heat up , got to 93 degrees when doing over 50 . Thank god it’s got silly tyres on to keep it slow , suppose I should pull the head in case the gasket is failing , or stay under 45 which is easier
Post #731843 29th Sep 2018 12:22pm
razz
New injector harness coming, new filters too , she was running a smidge rough today , bet it’s the Censored Sainsbury’s diesel
Post #731900 29th Sep 2018 7:17pm
L110CDL
You got it in one with the remark of the diesel Rolling Eyes 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #732294 1st Oct 2018 7:51pm
razz
so today , the thing came out for a spin , and it went like this , she starts on the button in the garage, but when its time to leave , it just clicks from the solenoid. hmmmmmmmmmm . anyways , a few swear words and we away , so shes gotta new injector harness , air and diesel filter and a bottle of diesel booster from halfords slung in to , do a 15 mile plod to esso and fill her up with premium diesel at 1.49 a litre , i then try to leave and click , click , click. some more swearing and she starts , a quick blast to work and i go underneath , clean the chassis earth and solenoid connections , and hooray , she works every time , afterwork , i drive to jsf norwich to get some magnetec for me engine , cos its not been changed in over a year , on the way there , the indicators pack up , so with some wire wiggling , they work once more , so with magnetec on board , we head head out for some high speed flat out runs ( ha ha ha ) long story shortened , shes now so smooth , up to 60 shes now a million percent better , at 70 the unbalanced muds are rubbish anyway , so several miles covered between 40 -55mph , temps are good , shes smooth , got power too , adjusted boost to give 226kpa , yep , really pleased , will let her cool down and then change the oil , bring on the pit
ady
Post #733287 6th Oct 2018 11:10am
razz
Yum yum
Post #733290 6th Oct 2018 11:13am
razz
Whilst investigating a ticking noise , I have found that the exhaust flexi bit under turbo is split and i’ve got a bust stud , so i’ll pull it apart , get some uprated studs , find somewhere to skim my manifold , get a new down pipe and put it all back together again , oh the joys
Post #733478 7th Oct 2018 4:01pm
razz
The broken stud was so easy to get out , the next one above which was also bust , is being very naughty indeed
Post #733496 7th Oct 2018 6:02pm
Procta
Asda Censored is no better either and that goes for the company and goods too, ( yeah I did work for them for a good few years) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #733505 7th Oct 2018 6:42pm
