Home > Maintenance & Modifications > winterisation
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
winterisation
So i walked outside at 5 this morning and nearly ended up with a nobsickle. And with Potentially 4 months of snow "When it snows in the sahara", and the coldest winter on record Expected by those that hold stock in hearsay.
I knew the day would come, so a few weeks ago i topped up the OAT from dry as a bone (how i didn't overheat doing 25 mile stints in 30 degree heat i'll never know).
So this will be my first winter (from the start) with lucinda and wondered whats entailed in the winterisation process?
✓ So topped up the OAT
✓ Tyres Still at winter pressures (lazy)
Snow cowls worth their money?
What about diesel fuel additives?
To check Heater now that the coolant is full.
Figure out what the heated seats are doing
Fix the Fluid squirter (no not that you dirty old gits)
Luckily My heated windscreen still works...
 I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #730923 24th Sep 2018 7:29pm
geobloke
So jealous of your heated screen Laughing Laughing
Get a new expansion tank cap, looks like you have had leakage at some point.
Post #730928 24th Sep 2018 7:45pm
sako243
Diesel fuel additives won't be required unless you're using so little you haven't filled up since the summer.
They're added in automatically by the fuel companies about this time of year. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #730955 24th Sep 2018 8:57pm
williamthedog
How old is the battery? Worth checking it out before the really cold weather comes Neutral
Post #730967 24th Sep 2018 9:21pm
roel
This is all I do for winterisation:
A warm hat and a insulated coverall. Twisted Evil
The 90 is winter/summer proof. Roel
2003 90 Td5 (2009-now)
Post #731073 25th Sep 2018 12:22pm
MartinK
Diesel should be OK to around minus 10 C without additives (i.e. as it comes from the pump). So unlikely a problem in England.
A couple of years ago in Scotland (Aviemore) it was around minus 16c for a few days. My TD5 Disco2 started, but the pump was whining noisily. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #731084 25th Sep 2018 1:25pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
proper landroverist right there !
Post #731097 25th Sep 2018 2:04pm
dantastic
A bag with warm clothes thrown in the back.
You never know when you might need it, or come across someone else who might.
Post #731102 25th Sep 2018 2:15pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I use silver heating tape to seal up the drafts. Usually seal under the flaps on the bulkhead, any panels I've had up like above the transfer box, and any where that is leaking on the heater.
When it gets really bad I fit a rad muff. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #731203 25th Sep 2018 8:36pm
