![]() | Home > Maintenance & Modifications > Terrain Tech Galvanised Bulkheads |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Just had a look at their website & the photo they use for their bulkheads looks identical to the one used by Shielder, even down to the out of alignment windscreen bracket holes... for a company that manufacture their own bulkheads from scratch that is a bit suspect to me
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
Just looked again and I hadn't noticed it was the same picture
Indeed highly suspect 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320 |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Try Robert at Mosside Land Rovers his bulkheads are excellent, I have fitted at least 10
Of them and have another two ready to go in ![]() |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 821 ![]() ![]() ![]() |
Must be able to fit them with your eyes closed then Nick
![]() Another vote for Robert.... hopefully he has mine ready soon ![]() |
how much would I be for one of those? 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
It’s bad when you can look at a box of bolts, clips and screws and know their location, vintage and placement ![]() Whats yours? and I’ll give him a gentle nudge when I’m there on Friday. Quality takes time you know ![]() The bulkheads vary on price depending on quality and repairs required. Contact him through eBay is maybe best and tell him Nick sent you ![]() eBay Item No. 163219615830 Last edited by NickMc on 30th Aug 2018 9:38pm. Edited 1 time in total |
thanks nick
Problem is I don't have anywhere to store my truck in bits, so i'll need to buy a bulkhead outright and then trade mine back in when it's all swapped over. Mine is starting to go next to the vent flap, a pillars and foot well top seam... so won't be a quick fix if I do go down that route 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320 |
No problems Ross
He has stock of some needing repaired at times or might do a deposit for return. I’ve bought them from him before without having something to go against. Sounds like a typical bulkhead repair ![]() Hopefully the shielded bulkheads fit better than the Chassis ![]() |
I've got a galvanised original chassis with some slightly wonky outrigger repairs... so I know it's going to be a bit of a nightmare whatever one I end up getting. The current standard bulkhead fit is terrible
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 ![]() ![]() ![]() |
Ross, my local Indy have fitted a few galv bulkheads, although I don't know who supplied them, and have had significant problems getting each one to fit with everything else lining up properly!
The general feeling is that hot dip galvanising results in a bulkhead being subject to warping due to the shape of a bulkhead and the boxed sections on it resulting in temperature changes in the dip. But you know me Ross, I may be talking my usual load of horse m4nur3!! |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1883 ![]() ![]() |
I had been told that what was needed was a 'jig' or frame to support the bulkhead in place while being dipped to stop it warping/bending. Obviously I couldn't manage that for a one-off, but maybe that's where trade suppliers come in?
Anyway, I got mine galved locally and must have been lucky because it came out fine. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
