Home > Maintenance & Modifications > Terrain Tech Galvanised Bulkheads |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Just had a look at their website & the photo they use for their bulkheads looks identical to the one used by Shielder, even down to the out of alignment windscreen bracket holes... for a company that manufacture their own bulkheads from scratch that is a bit suspect to me
30th Aug 2018 7:45am |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
Just looked again and I hadn't noticed it was the same picture
Indeed highly suspect 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320 |
30th Aug 2018 8:04am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
Try Robert at Mosside Land Rovers his bulkheads are excellent, I have fitted at least 10
Of them and have another two ready to go in |
30th Aug 2018 3:30pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 817 |
Must be able to fit them with your eyes closed then Nick
Another vote for Robert.... hopefully he has mine ready soon |
30th Aug 2018 5:54pm |
how much would I be for one of those? 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
30th Aug 2018 6:56pm |
It’s bad when you can look at a box of bolts, clips and screws and know their location, vintage and placement Whats yours? and I’ll give him a gentle nudge when I’m there on Friday. Quality takes time you know The bulkheads vary on price depending on quality and repairs required. Contact him through eBay is maybe best and tell him Nick sent you eBay Item No. 163219615830 Last edited by NickMc on 30th Aug 2018 8:38pm. Edited 1 time in total |
30th Aug 2018 7:15pm |
thanks nick
Problem is I don't have anywhere to store my truck in bits, so i'll need to buy a bulkhead outright and then trade mine back in when it's all swapped over. Mine is starting to go next to the vent flap, a pillars and foot well top seam... so won't be a quick fix if I do go down that route 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320 |
30th Aug 2018 8:33pm |
No problems Ross
He has stock of some needing repaired at times or might do a deposit for return. I’ve bought them from him before without having something to go against. Sounds like a typical bulkhead repair Hopefully the shielded bulkheads fit better than the Chassis |
30th Aug 2018 8:37pm |
I've got a galvanised original chassis with some slightly wonky outrigger repairs... so I know it's going to be a bit of a nightmare whatever one I end up getting. The current standard bulkhead fit is terrible 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
31st Aug 2018 10:22pm |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 |
Ross, my local Indy have fitted a few galv bulkheads, although I don't know who supplied them, and have had significant problems getting each one to fit with everything else lining up properly!
The general feeling is that hot dip galvanising results in a bulkhead being subject to warping due to the shape of a bulkhead and the boxed sections on it resulting in temperature changes in the dip. But you know me Ross, I may be talking my usual load of horse m4nur3!! |
21st Sep 2018 2:00pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
I had been told that what was needed was a 'jig' or frame to support the bulkhead in place while being dipped to stop it warping/bending. Obviously I couldn't manage that for a one-off, but maybe that's where trade suppliers come in?
Anyway, I got mine galved locally and must have been lucky because it came out fine. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
21st Sep 2018 2:35pm |
