Home > My Defender > 2013 Defender 90 XS tasteful mods.... |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4226 |
Why do those switch relocation panels always have that big round hole at the bottom? 2007 110 TDCi Station Wagon XS
11th Sep 2018 5:55pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20563 |
Dynamat interior helps a lot, bonnet is often not worth it as sound "leaks" from everywhere in the vicinity anyway.
Bluest - It does have a purpose (round dial.) but most people including myslef don't like it! Far better to be squared off matching the top edge. KEEP CALM AND Drill ON š¬š§š“ó §ó ¢ó „ó ®ó §ó æš“ó §ó ¢ó ·ó ¬ó ³ó æš“ó §ó ¢ó ³ó £ó “ó æš®šŖšŗšøā½ļøš¢ļøāļøš§°šŖ |
11th Sep 2018 5:57pm |
It will. The roof and rear wheel boxes are well worth doing too, especially when teamed with some 6mm foam over the top. The Puma bonnet is already pretty stiff, which is why Dynamat doesn't really help there. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
11th Sep 2018 6:00pm |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 379 |
Thanks all.
Agree the dial space is a pain, I guess first person to create the template wanted one and everyone else just copied it. I may put an internal/external temp gauge in, or altimeter? If anyone has suggestions for something EASY, please shout. The rear in mine doesnt have carpet on the wheel arch boxes so I am hoping once I dynamat and carpet that it will make more difference! |
11th Sep 2018 6:15pm |
Stonechipping the under arches road side helps also, but does need to be clean and prior to Dinitrol application to metal areas.
Helps a lot on plastic arches under the front too, but as I said must be clean first. All the different things added together help a lot. KEEP CALM AND Drill ON š¬š§š“ó §ó ¢ó „ó ®ó §ó æš“ó §ó ¢ó ·ó ¬ó ³ó æš“ó §ó ¢ó ³ó £ó “ó æš®šŖšŗšøā½ļøš¢ļøāļøš§°šŖ |
11th Sep 2018 6:32pm |
good tip, thanks
11th Sep 2018 7:33pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Great start looks good! James
11th Sep 2018 7:49pm |
I always wondered. Iād stick a voltmeter or USB port in there or something. 2007 110 TDCi Station Wagon XS |
11th Sep 2018 8:23pm |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 259 |
How about this .
Main light switch from P38. Click image to enlarge |
11th Sep 2018 9:51pm |
Rear Dynamated and fitted with carpet today. Ran out of time to try it to see the effect!
16th Sep 2018 6:42pm |
Stu_XS Member Since: 22 Jul 2018 Location: Hampshire Posts: 86 |
Looks good. Did the same with mine as soon as I got it.
I have used Dynamat in the roof and inside the front doors but tempted to drop the headlining again to add some foam. Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
16th Sep 2018 7:45pm |
LR are replacing the headlining when the new one comes in - it is sagging slightly in the middle. Not quite sure why they couldn't sort that without replacing it
16th Sep 2018 9:10pm |
In that case, it'd pay to remove the existing and install foam before taking it in for the new one to be fitted. Obviously no need to reinstall the old one. Darren
17th Sep 2018 7:34am |
How hard is it to remove/fit? (Just talking rear section)
17th Sep 2018 7:40am |
