Home > My Defender > 2013 Defender 90 XS tasteful mods....
Page 1 of 4 1234>
edo
First job ticked off. Really decent unit.
Ignore the finger prints and the weird lines are reflections not scratches!
had a panic one of the heated seats stopped working but it was just a fuse!
I also added Dynamat to the underside of the bonnet which if you are thinking of doing was a complete waste of time. I am hoping the interior floor kit yields better results.
Post #728501 11th Sep 2018 3:28pm
Bluest
Why do those switch relocation panels always have that big round hole at the bottom? 2007 110 TDCi Station Wagon XS
Post #728514 11th Sep 2018 5:55pm
Dynamat interior helps a lot, bonnet is often not worth it as sound "leaks" from everywhere in the vicinity anyway.
Bluest - It does have a purpose (round dial.) but most people including myslef don't like it!
Far better to be squared off matching the top edge. KEEP CALM AND Drill ON
šŸ‡¬šŸ‡§šŸ“󠁧󠁢󠁄󠁮󠁧ó æšŸ“󠁧󠁢󠁷󠁬󠁳ó æšŸ“󠁧󠁢󠁳󠁣󠁓ó æšŸ‡®šŸ‡ŖšŸ‡ŗšŸ‡øā›½ļøšŸ›¢ļøāš™ļøšŸ§°šŸ’Ŗ
Post #728515 11th Sep 2018 5:57pm
Re: 2013 Defender 90 XS tasteful mods....
It will. The roof and rear wheel boxes are well worth doing too, especially when teamed with some 6mm foam over the top.
The Puma bonnet is already pretty stiff, which is why Dynamat doesn't really help there. Darren
Post #728516 11th Sep 2018 6:00pm
edo
Thanks all.
Agree the dial space is a pain, I guess first person to create the template wanted one and everyone else just copied it.
I may put an internal/external temp gauge in, or altimeter? If anyone has suggestions for something EASY, please shout.
The rear in mine doesnt have carpet on the wheel arch boxes so I am hoping once I dynamat and carpet that it will make more difference!
Post #728519 11th Sep 2018 6:15pm
Stonechipping the under arches road side helps also, but does need to be clean and prior to Dinitrol application to metal areas.
Helps a lot on plastic arches under the front too, but as I said must be clean first.
All the different things added together help a lot. KEEP CALM AND Drill ON
Post #728522 11th Sep 2018 6:32pm
edo
good tip, thanks
Post #728537 11th Sep 2018 7:33pm
JOW240725
Great start looks good! Thumbs Up James
Instagram @suffolk_rovers
Post #728542 11th Sep 2018 7:49pm
Bluest
Thumbs Up I always wondered. Iā€™d stick a voltmeter or USB port in there or something. 2007 110 TDCi Station Wagon XS
Post #728548 11th Sep 2018 8:23pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
How about this .
Main light switch from P38.
Post #728558 11th Sep 2018 9:51pm
edo
Rear Dynamated and fitted with carpet today. Ran out of time to try it to see the effect!
Post #729319 16th Sep 2018 6:42pm
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Looks good. Did the same with mine as soon as I got it.
I have used Dynamat in the roof and inside the front doors but tempted to drop the headlining again to add some foam. Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #729355 16th Sep 2018 7:45pm
edo
LR are replacing the headlining when the new one comes in - it is sagging slightly in the middle. Not quite sure why they couldn't sort that without replacing it
Post #729403 16th Sep 2018 9:10pm
In that case, it'd pay to remove the existing and install foam before taking it in for the new one to be fitted. Obviously no need to reinstall the old one. Darren
Post #729430 17th Sep 2018 7:34am
edo
How hard is it to remove/fit? (Just talking rear section)
Post #729431 17th Sep 2018 7:40am
Page 1 of 4 1234>
