Home > Maintenance & Modifications > Anyone have or fitted the Safety Devices L243 Roll Cage ?
Page 5 of 5 <12345
hank
Bankz, see here where you cut a hole in the front wing for the a pillar bar to connect down to the chassis? Can I do this without cutting the hole, but just drilling four holes for the bolts?
So instead of the top connector plate being in direct contact with the bottom connector plate it would be top connector - wing - bottom connector
Difficult to explain in writing - hopefully you catch my drift
This image shows the hole
https://www.landyzone.co.uk/attachments/27...pg.142229/
Post #728280 10th Sep 2018 1:52pm
bankz5152
No as the plate has a raised middle, some sits behind the body work, then protrudes through. You have to cut the hole. Instagram @defender_ventures
Empire Tuning - Agent
Post #728299 10th Sep 2018 3:11pm
hank
Okiedokie thanks
Post #728309 10th Sep 2018 4:38pm
Grenadier
bankz5152 wrote:
Grenadier wrote:
I heartily agree. Thumbs Up
Where did you get those nets from?
Then worth doing!! Was 3.5" exhaust sections. X3 tight 90 degrees x1 60 degree, 900mm straight
Not mine Bankz, belongs to Davina McCall's husband who runs a travel company, "Momentum Adventures". But I have seen the nets on-line. This lot have a good selection:
https://rocknroad4x4.com/product-category/webbing-cargo-nets/
It's a good look in my opinion. My also have some use as well Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #728310 10th Sep 2018 4:43pm
Page 5 of 5 <12345
