Home > Maintenance & Modifications > Anyone have or fitted the Safety Devices L243 Roll Cage ?
Page 3 of 5 <12345>
JJ
United Kingdom 1987 Defender 110 V8 Petrol CSW Corris Grey
I've got the L242 fitted to mine by a professional company and they did struggle to make it fit and still be able to open the doors as the cage pinched the body in when fitted. They got there in the end with a lot of fettling so I think your measure ( at least twice ) cut once philosophy will stand you in good stead. HR064 Hampshire and Berkshire 4x4 Response
Post #683589 2nd Feb 2018 9:29am
agentmulder
Kuwait
Did the L242 by myself in the driveway over 3.5 days.
Thon has it right regarding not trusting the templates and trying to assemble the unit on the vehicle before actually cutting the required holes, 'just to make sure' Laughing
Frustration level amounts to pretty much the satisfaction level for the install, but satisfaction level maintains itself over time, so yeah, pull that trigger! Solved the bowel problem, working on the consonants...
Post #683591 2nd Feb 2018 10:14am
bankz5152
Good to know it is doable then! Got a big drive way and a house is being built next door, im sure i could blag a forklift & driver if needed Laughing
So suggested idea is to mark everything out.
Build the cage
Offer up and check fitting before cutting
Post #683599 2nd Feb 2018 11:15am
Mo Murphy
Get the front hoop assembled and fitted first, that only goes in one place and then work back from that. Use common sense and logical progression. Take your time and measure 3 times before cutting because once it's cut, it's cut. If you're not sure, stop have a cup of tea, have a think and then go back to it. Do not set a deadline to finish fitting it, it'll only make you rush, let it take as long as it takes.
HTH
50 Shades of Pennine Grey
Post #683606 2nd Feb 2018 12:02pm
bankz5152
Thon wrote:
Yes it's all perfectly feasible to do at home if you have space and tools. Also bear in mind that some of the parts are quite heavy and unwieldy so having 2 of you will probably be required at some point. One thing that nearly caught me out was the initial delivery of the kit - I was going to have it delivered to home, but in the end managed to get it delivered to the workshop (which has a fork truck) - just as well as it was in the back of a courier van and weighed something more than 150 Kg in a single crate. Not a chance that I would have been able to get that in my trailer on my own.
Another thing to consider is the weight of the cage once fitted, and the effect this has on C of G. Mine runs standard (but new) suspension and it is quite noticeable. If you were running a lift and some relatively soft springs, particularly without anti-roll bars, I would be prepared for quite a change in its road behaviour.
I'm afraid I don't have the installation instructions for an external cage but I would imagine that it would work in a similar way, but instead of the chassis connecting plates picking up on an inner "C" pillar hoop, there's a transition piece to match the internal structure to the rear tub penetration point for the external hoop. If you email SD they will happily send you the instructions on PDF.
It's all a question of the same process: offer-up, measure, mark, get paranoid, re-offer-up, measure, measure again, mark slightly differently, offer-up, re-measure, go back to original marks, get fed up, drill the f*cker anyway and hope for the best ....
Or maybe that's just me Rolling with laughter
Shouldnt be an isse re suspension my old 90 had a cage and drove fine with no ARBs and a small lift. The 110 has TF medium load springs + TF +2 big bore dampers (may change to OME +2s tho..) should be up to the job Smile
Im only in 3 days a week from the 12th and dont need my 110 daily so should be alright for time!
Post #683613 2nd Feb 2018 1:09pm
bankz5152
HTH
Mo
Looking at pics it doesnt look like you can assemble just the front hoop, looks like either the whole thing or nothing
Post #683996 4th Feb 2018 8:41am
agentmulder
Kuwait
Buy it and install it already Laughing Solved the bowel problem, working on the consonants...
Post #683997 4th Feb 2018 8:44am
bankz5152
Im going to! Probably order it Sunday/Monday as im off week after next.
Post #684008 4th Feb 2018 9:27am
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Stop posting pictures of roll cages, Your making me want one. Laughing Laughing Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #684025 4th Feb 2018 10:33am
MartnH
Australia
bankz5152 wrote:
So rollcage time is approaching soon. In two minds what to do now, looks like the external only cages are quite straight forward to fit, making me think I should have a go a fitting it at home, got quite a big garage so most the work can be done indoors.
From what ive read it seems like a case of measuring carefully, cutting carefully and bolting together!
Anyone got any insight on how the bracket behind the rear/middle doors fits?
this is my version of installation instructions.
trust me the manual is useless. well its done in a similar fashion of Mantec manusla. only photos no words....
front cage support :
-take the wing skin off, around ten bolts inside the engine bay
cut rectangle shape hole on the wing skin.
bolt bracket on firewall, refit wing skin. make sure the roll cage bracket stick out from the cut holes
job done
-middle suppot
take the factory plate off (under B pillar.) cut it according to template
fit the support bracket.
job done
-rear support,
install the support brackets. its two parts. bottom part bolts on the chassis, top part in the cabin and bolted onto the bottom part while the other end stick out the cut holes.
job done
so up till now, you have install all the support brackets and the next step is simply put the hoops, links onto these supports brackets....
Post #684495 6th Feb 2018 11:51am
bankz5152
Thanks! Smile
Dont suppose you have ang decent pics of the middle/rear mounts?
Post #684561 6th Feb 2018 5:38pm
bankz5152
Ordered! From LR Direct for a very good £1330 shipped!!
Post #685064 8th Feb 2018 5:19pm
bankz5152
Cage is arriving tomorrow, so thought I would made a start this evening!
Removed both wings in around 2hrs30. Surprisingly wasnt too difficult.
Offside off, pretty simple. Removed the extended arch, snorkel and rubber inner liner (aftermarket I think, with the arches). Gave me plenty of access to all of the bolts which to my surprise where not seized in anyway. Best part is the air intake hole made for excellent access to the bulkhead/wing bolts. These came off with a 14mm socket. The rest of the surrounding bolts where 11mm.
Nearside outer wing was a little more difficult to remove, took a little longer. Mainly due to the bulkhead/wing bolts which are 13.5mm heads? Shocked
13mm socket wouldnt fit, 14mm socket just span, 9/16th didnt fit either. Manged to get it off in the end by hammering a 13mm socket on Embarassed
Also removed about 2kg of mud!!
Could anyone ID these connectors and this dohickey?
Post #686194 12th Feb 2018 9:37pm
First photo - connectors for rear washer (2 pole) and headlight levelling motor (3 pole).
Second photo - connector for alarm BBUS (if fitted).
Third photo - alarm sounder (not battery backed).
You seem to be missing the offside horn.
Post #686213 12th Feb 2018 10:25pm
bankz5152
Ahh that makes sense as its a DCPU and thus no rear jets.
Horn is there just moved for security reasons. I dont appear to have a BBSU can one be retro fitted?
Post #686219 12th Feb 2018 10:35pm
Page 3 of 5 <12345>
