![]() | Home > Tdi > 300tdi EGR ECU |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
There won't be any faults if you remove it as the system only reads other information to operate the EGR valve.
Can remove the modulator from the bulkhead, unplug the injection pump sensor, the vacuum hose needs sealing up and the ECU can be unplugged. |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5240 ![]() ![]() |
Yeah just blank the full lot off under the bonnet, with the kit. Then just unplug the EGR ECU and bin the full lot. ![]() Mine was really sluggish with it on, as soon as i binned it, it made the motor a lot more lively ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 ![]() ![]() ![]() |
Same as above by Procta. Engine runs a lot better now.
Simon ![]() |
