Home > Tdi > 300tdi EGR ECU
Dream300110
1997 Defender 110 300 Tdi CSW Epsom Green
300tdi EGR ECU
I'm looking at fitting an EGR blanking kit on my 300tdi 110, I'd like to remove the whole valve system. I know it's got the EGR ECU under the centre cubby box. Question is, will I have any faults or issues come up by doing this and also, is it possible to remove the entire system, ECU and all?
Post #728127 9th Sep 2018 6:45pm
dailysleaze
There won't be any faults if you remove it as the system only reads other information to operate the EGR valve.
Can remove the modulator from the bulkhead, unplug the injection pump sensor, the vacuum hose needs sealing up and the ECU can be unplugged.
Post #728235 10th Sep 2018 8:09am
Procta
Re: 300tdi EGR ECU
Yeah just blank the full lot off under the bonnet, with the kit. Then just unplug the EGR ECU and bin the full lot. Thumbs Up
Mine was really sluggish with it on, as soon as i binned it, it made the motor a lot more lively Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #728565 12th Sep 2018 5:06am
shayes
United Kingdom 1998 Defender 90 300 Tdi HT Coniston Green
Same as above by Procta. Engine runs a lot better now.
Simon Very Happy
Post #728582 12th Sep 2018 8:19am
