Home > Td5 > TD5 Non Start
Page 4 of 5 <12345>
Td5Cam
Just tridled multiple points and still only showing 2v at most
Post #726117 29th Aug 2018 5:13pm
Td5Cam
Tried*
Post #726118 29th Aug 2018 5:14pm
dorsetsmith
Td5Cam wrote:
Bulkhead earths look ok
Tried grounding to engine and nothing
from engine to witch point Question
Post #726125 29th Aug 2018 5:44pm
Td5Cam
His was in response to taking earth from battery to engine, i connected it to multiple points on engine and gearbox
Post #726132 29th Aug 2018 5:52pm
Td5Cam
Would it be worth trying a ground from -ve on battery to the starter motor itself?
Post #726140 29th Aug 2018 6:12pm
dorsetsmith
Try it
Post #726142 29th Aug 2018 6:15pm
Td5Cam
Will give it a try tomorrow, its bound to be something simple, as seems odd for it just to stop working after it stalling.
Thanks for help so far.
Post #726144 29th Aug 2018 6:18pm
dorsetsmith
battery neg cable from battery to chassis and on the transfer box
Razz this one had bad crimp lug
Post #726148 29th Aug 2018 6:26pm
Td5Cam
Is that a clue to my problems Laughing
Post #726154 29th Aug 2018 7:02pm
Td5Cam
If that was damaged or lose in anyway would that explain why there is such low voltage when take a ground from the engine when measuring the voltage of the starter? Just seems odd to get 2v from taking a ground from the engine to getting 12.4v from the bulkhead ground Confused
Post #726227 30th Aug 2018 7:57am
dorsetsmith
the neg go to the chassis to start with and then on to the transfer box, on driver side there braided cable link from chassis to the bulkhead if you problem with the cable or crimp lug at the transfer box end
Post #726230 30th Aug 2018 8:06am
grafty99
As I said 4 pages ago, check you have a good earth to the gearbox/transfer box. If there is a poor connection then the resistance in the circuit will only show 2V. There is obviously a good connection to the starter so it is getting 12V but it's only getting a partial earth so showing 2 volts.
Try putting a jump lead between battery negative and the engine. I bet it will solve it Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #726267 30th Aug 2018 12:02pm
Td5Cam
So gave it another go with the jump lead from -ve terminal to engine, at first didnt get anything (this could be down to my jump lead) but after a bit of a wiggle i managed to get all dash lights and could hear the fuel pump prime, it didnt start but it certainly was some way forward so pretty confident now its the ground/earthing thats at fault, will give it closer look at weekend
Post #726313 30th Aug 2018 6:19pm
dorsetsmith
not all of them but at lest your moving forward
replacement or rework neg battery cable next
Post #726318 30th Aug 2018 6:31pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
The TD5 starter requires a very strong connection to the battery to get the engine going as I've found out from personal experience.
Jump leads don't always transfer enough current, probably due to the croc clips Thumbs Up
Post #726506 31st Aug 2018 6:14pm
Page 4 of 5 <12345>
