Home > Td5 > TD5 Non Start
Page 2 of 5 <12345>
dorsetsmith
Post #726027 29th Aug 2018 9:23am
Td5Cam
I dont have an immobiliser enabled on mine and there is feed going through the starter relay.
Also the immobiliser warning lamp isnt flashing.
Post #726029 29th Aug 2018 9:30am
dorsetsmith
there is feed going through the starter relay. ? and will not the engine turning over on the starter motor.
Post #726030 29th Aug 2018 9:36am
Td5Cam
Correct, nothing happens just have the amber fog lamp dispmay on the dash which i dont understand...
Post #726033 29th Aug 2018 9:41am
dorsetsmith
wrong diagram
Post #726035 29th Aug 2018 10:06am
Td5Cam
Yes there is a feed going through the starter relay and through to the starter motor itself
Post #726036 29th Aug 2018 10:12am
Td5Cam
This is what i see when i turn ignition on
The EML and Coil lights extinguish and the just left with the fog lamp on
Post #726037 29th Aug 2018 10:15am
dorsetsmith
you have pre 2000 TD5 Question
Post #726038 29th Aug 2018 10:17am
Td5Cam
Its 1999
Post #726039 29th Aug 2018 10:17am
dorsetsmith
ok that changes things diagrams fuse box and relay lay out
Post #726040 29th Aug 2018 10:20am
dorsetsmith
Censored
Post #726043 29th Aug 2018 10:44am
dorsetsmith
The EML lamp extinguish on start up to test the light and Coil lights extinguish glow plug time out
Post #726044 29th Aug 2018 10:53am
grafty99
As there is no oil pressure, handbrake warning or charge warning light there is definately some things not getting power. When you stalled it was it quite a violent stall? It may have unplugged something in the loom... 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #726045 29th Aug 2018 11:02am
Td5Cam
If i leave the ignition on the warning lamps do come on after some time, but if you then go to turn it over you can hear the starter motor engage but then nothing just back to square one with no warning lamps again.
The stall wasnt particularly violent no.
Post #726046 29th Aug 2018 11:13am
Td5Cam
If there is a feed going through the starter relay, does that necessarily mean that there should be a feed going through the main relay? Just wondering if maybe its the main relay at fault because there is no fuel pump sound or the normal warning lamps to be expected from ignition
Post #726055 29th Aug 2018 12:23pm
Page 2 of 5 <12345>
