Home > Technical > puma dead when turning on |
Noiseydave Member Since: 27 Dec 2015 Location: West Midlands Posts: 43 |
Had similar, turned out to be ignition switch and wiring to it. Repced switch and all has been good since. I also suggest you check the earths
26th Aug 2018 6:03am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2046 |
Battery connections ?
26th Aug 2018 8:51am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20506 |
Battery connections being loose will do that as mentioned by Daz above.
Check the easiest things first, check the Rekays are secure under the drivers seat also. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
26th Aug 2018 1:53pm |
rillas Member Since: 27 May 2012 Location: warilla nsw 2528 Posts: 16 |
thanks
27th Aug 2018 1:43am |
I've had a similar issue that was due to one of the under seat relays getting loose. I had to tighten up the terminals in the end but it's been fine since.
12th Sep 2018 1:53pm |
