Home > Technical > puma dead when turning on
rillas
Australia 2003 Defender 90 Td5 HT Tonga Green
my 110 2009 puma has started playing up need advice it goes well but sometimes go to start and is dead turn off key then try again and it goes put nannocom on no fault comes up any suggestions
Post #725397 26th Aug 2018 5:34am
Noiseydave
United Kingdom 2009 Defender 110 Puma 2.4 XS DCPU Santorini Black
Had similar, turned out to be ignition switch and wiring to it. Repced switch and all has been good since. I also suggest you check the earths
Post #725399 26th Aug 2018 6:03am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Battery connections ?
Post #725413 26th Aug 2018 8:51am
Battery connections being loose will do that as mentioned by Daz above.
Check the easiest things first, check the Rekays are secure under the drivers seat also. No Guts, No Glory.
Post #725456 26th Aug 2018 1:53pm
rillas
thanks
Post #725565 27th Aug 2018 1:43am
Cupboard
I've had a similar issue that was due to one of the under seat relays getting loose. I had to tighten up the terminals in the end but it's been fine since.
Post #728615 12th Sep 2018 1:53pm
