Home > Camping, Caravanning and Holidays > Gas stove recommendations
Page 2 of 3 <123>
jst
thats what i would do if it doesnt fit. just back from 7 days family camping with two coleman stoves, wouldnt use anything else. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #724543 21st Aug 2018 10:56am
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Ok, I’m convinced! Just one thing you Coleman owners could help with are the dimensions, on the Coleman EU site
https://www.coleman.eu/uk/p-23734-unleaded-2-burner-stove.aspx
the footprint of the stove is given as 46 x 29 cm, the width is no problem but the depth may be, does the 29cm include the fuel tank? If not, how much does it add to the depth?
Thanks,
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #724591 21st Aug 2018 2:55pm
josefk
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
hi Chris,
I'm not at home to check the measurements on my coleman but no the 29cm depth isn't with the petrol tank fitted. I would estimate the tank adds ~10cm to the depth when fitted. Of course the tank goes inside the stove when its packed up so the 46x29x12 is correct for a stove "in transit" rather than in use.
Post #724764 22nd Aug 2018 9:17am
ChrisCM
Thanks Josefk, since posting here others have told me what you’ve said and that the tank is self supporting on its lugs so should be ok on the cooker housing, just ordered one so I’ll find out for myself soon 👍 I’ll post a photo when it arrives. 2010 Defender 110 Station Wagon, Santorini Black.
Post #724791 22nd Aug 2018 11:59am
josefk
nice one Chris.
at the risk of sounding patronising i found the stove to be a bit of a struggle at first - coming from a really nice multifuel MSR i found pressurising the coleman comparatively awkward (both before and during use). Now it's second nature and I find it a really excellent tool.
basically if your like me you may initially wonder what all the fuss is about but don't worry...
cheers
Post #724804 22nd Aug 2018 1:23pm
ChrisCM
I like a challenge! So looking forward to a play. 2010 Defender 110 Station Wagon, Santorini Black.
Post #724851 22nd Aug 2018 3:39pm
jst
comments on getting used to it are well founded. they are cracking stoves but it can take a fair bit of time and patience to learn the most efficient ways of running it. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #724901 22nd Aug 2018 7:20pm
ChrisCM
The Coleman arrived this morning, less than 24hours after ordering it.
Fuelled her up and she lit no problem, took a bit of time to get a blue flame, the tops were tinged yellow, had a couple of pops and the flame went yellow then with a bit of fiddling with the burner control got it blue again, bit of soot on the burner top, generator and the bottom of the kettle, may be that it’s new and needs running in? 😀
All shiney and new 😀
In position on the cooker housing
Thar she blows ! 2010 Defender 110 Station Wagon, Santorini Black.
Post #725090 23rd Aug 2018 6:54pm
Devon-Rover
Yellow flame suggest incomplete burn either fuel or air. did you prime the tank sufficiently? also the priming plunger should have a small hole in the securing ring to allow a drop of light oil like 3 in 1 just to keep the seal happy.
It should be the same process like the 533 and the 442 that I have which is a 30second prime 91 pump per second) light it then pump until the plunger can be held against the pressure about a 1/2 inch up against your finger pushing down.
Colemans are fantastic stoves having actively used my sportster for something going on like 12 years. mostly run on petrol and occasionally coleman fuel and only just recently replaced the generator for the first time as performance was dropping off.
Like landys one isn't enough,, so you'll need a single burner then a lantern and then a twin mantle as they are really bright. Rolling with laughter Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #725111 23rd Aug 2018 8:16pm
leeds
Now that is one nice looking Coleman and that kettle is like a mirror! Somehow I do not think I will put up a photo of our Coleman.
A second tank/generator is useful for fast change over if doing a lot of cooking. Now if running on petrol it is easier to carry the petrol in say 0.5/1 litre Ali bottles for filling the Coleman tank.
Brendan
Post #725114 23rd Aug 2018 8:26pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
Slightly smaller gas stove but it's the mutts nuts and easy accommodates a large pan , kettle or frying pan
https://www.outdoorgear.co.uk/Vango-Roar-S...JsQAvD_BwE
Post #725138 23rd Aug 2018 11:14pm
familymad
I took a screen shot from an older Coleman of how to light as I lost my instructions ages ago! Might be of use in 12 months when you get it out again!!
 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #725151 24th Aug 2018 4:39am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Use an MSR Dragonfly myself. Have an Optimus Crux for when I need to fly but I also use it for a quick coffee ottes on the road. The Coleman dual burner is somethingI still need to buy. Not really needed,but a man needs his toys... 😬
Post #725164 24th Aug 2018 7:25am
dantastic
Congrats on your purchase! You won't be disappointed!
I use one of these for fuel. Comes with a handy spout and 2l is more than enough for a really long time.
https://www.amazon.co.uk/Hunersdorff-81020...B001IX673M
Post #725208 24th Aug 2018 12:30pm
dorsetsmith
Halon Fire Extinguishers Whistle
Post #725211 24th Aug 2018 12:46pm
Page 2 of 3 <123>
