Home > Camping, Caravanning and Holidays > Gas stove recommendations
Page 1 of 3 123>
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
I have an MSS cooker housing, when I bought it new from a guy on the Angry Pumas fab group it came complete with a 2 burner Gelert stove, also new, trouble is it’s not a very good stove! It’s very difficult to get a low flame without it blowing out. As it was an unexpected extra with the housing I’m not too disappointed. So, can anybody suggest a suitable replacement which will fit the housing?
 2010 Defender 110 Station Wagon, Santorini Black.
Post #721926 7th Aug 2018 12:06pm
jst
yes - petrol Coleman - sorry doesnt answer the gas question but Coleman stove is fantastic, great bit of kit. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #721957 7th Aug 2018 2:32pm
NickBristol
Not sure it’ll fit but I’ve got a Coleman FyreChampion gas burner that’s excellent. Just Googled the size and it’s 68cm x 17cm x 38cm
Post #721966 7th Aug 2018 3:02pm
leeds
Agree about the Coleman petrol stove, even if ours is looking past its best still works fine.
I seem to recall the MSS oven housing had side shields to prevent stove being blown out by wind?
Brendan
Post #721967 7th Aug 2018 3:03pm
ChrisCM
Couple of ideas to think about, hadn’t considered petrol!
Yes Brendon, it does have side shields but I’ve found that, even with these deployed it can blow out, seems to be an all or nothing type stove unless it’s a windless day, also, this particular stove seems to sit well forward in the housing so the shields aren’t very effective. 2010 Defender 110 Station Wagon, Santorini Black.
Post #721985 7th Aug 2018 3:35pm
wyvern
We bought a Camping Gaz 2 feux 400 S Xcelerate Stove Burner System about 4 moths ago. Its designed to work in the wind.
So far we are very impressed. Its very quick and burns very hot, its quicker than our previous fitted cooker.
not great build but will modify if needed.
about £80 from Amazon Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #722073 7th Aug 2018 8:12pm
deejayen
They're very expensive, but these Partner Stoves look nice:-
http://mohicantents.co.uk/#/stoves/4575624073
Post #722120 8th Aug 2018 6:24am
Harry.O
Another vote for the Coleman petrol stove, great bits of kit. They are meant to run on a specific type of fuel but I run mine on petrol and it’s fine. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #722188 8th Aug 2018 11:09am
Mdm
another vote for coleman had 3 since i was a lad. cheap to buy 2nd hand great in all weathers in very cold weather that stops gas ones working.
for fast brew stops we have a jet boil as well.
the copies are ok but use more gas we found
Post #722395 8th Aug 2018 10:16pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
I have one of the Partner stoves, imported it direct from the states a few years back. Very expensive and a little indulgent but a fantastic piece of kit, solid built and simple design that will last for years. Will see if I can take a couple of photos later.
Post #722428 9th Aug 2018 7:31am
dantastic
Another vote for the petrol coleman. I absolutely love mine!
Post #722474 9th Aug 2018 11:01am
ChrisCM
I too have a jet boil type stove, mines a Primus Lite+, very fast for a quick brew so I suppose it wouldn’t matter if the petrol Coleman takes a bit of time to get going, how are they for a low, simmering heat?
Btw, like the look of the partner stove but I don’t think my bank balance would stand it! 2010 Defender 110 Station Wagon, Santorini Black.
Post #722736 10th Aug 2018 7:56pm
dantastic
The coleman really doesn't take any time to get going. Like 20 sec perhaps. I run my 2 stpves on Aspen fuel, a bit nicer to deal with and very nice burn. I also use a blowtorch attachment on a regular butane canister to get it started. Not really necessary but it's super handy, especially in a bit of wind. The extra heat of the torch will have you going just as fast as any gas stove.
I have a "regular" 2 ring coleman and also a single burner, a featherlite, for quick stops. Both fantastic.
Yes, you can simmer. The 2 burner has what I would call a master and a slave ring. The master must always be on if you are using the slave. Bit funny system but you will get used to it. The second burner is smaller as well so handy for simmering while cooking on the main burner.
The colemans are really great. There is a small bit more work involved perhaps but so worth it being able to just use cheap petrol. They burn really hot too, you won't be waiting long for a cuppa.
Post #723221 13th Aug 2018 2:24pm
jst
i have two coleman double burner stoves, one of them 10years plus now and the other bought 2nd hand on here. i use the 10year old one 90% of the time when out and use both when camping with the family.
I also use a Coleman featherlite which is same principle.
All these ^^ are easily controllable to simmer to jet boil equivalent.
For bike packing i picked up an Primus Omnifule multifuel https://www.outdoorgear.co.uk/Primus-Multi...gITfPD_BwE
Great for boiling quick, not so great for simmer, work with diesel, petrol and LPG just change the jet on it. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #723227 13th Aug 2018 3:16pm
ChrisCM
Very tempted by the Coleman dual fuel, nice retro looking piece of kit which seems to get good reviews regarding its performance, only problem is that while it would sit on the open table for cooking, it won’t fit into the housing when stored, it needs to be no more than 80mm high folded. Maybe I should just store it in the vehicle and put it on the unfolded table to cook, using the storage space in the housing for utensils etc? Hmmm.... 2010 Defender 110 Station Wagon, Santorini Black.
Post #723369 14th Aug 2018 8:59am
Page 1 of 3 123>
