Home > Puma (Tdci) > Steering judder/vibration not wheel balance
JOW240725
Our 2012 Puma with 58k miles has developed a slight steering judder at speeds 50mph+. Initially, I just thought the wheels needed rebalancing but that hasn't helped. I suspect UJ's, but where to start checking first?
Also if it is a UJ, is there an upgrade I ought to be thinking about?
 James
Instagram @suffolk_rovers
Post #724378 20th Aug 2018 3:00pm
williamthedog
Judder or wobble?
If its a wobble look at swivel preload.
Judder under braking could be warped discs. I think you mean wobble that's the most common problem.
Post #724401 20th Aug 2018 4:31pm
JOW240725
Its exactly like out of balance wheels, whilst driving, certainly not a braking issue. I'll add swivel preload to the list of possibles, thank you.
It'll be my garage man that looks at it but I like to point him in the right direction, so it seems like I know what I'm talking about (he knows I don't!) Embarassed James
Post #724406 20th Aug 2018 4:52pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Perhaps a weight might have come off one of the wheels? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #724408 20th Aug 2018 5:03pm
JOW240725
Thanks, but the first I did was get them all rebalanced, so ruled that out. James
Post #724410 20th Aug 2018 5:06pm
I would suggest swapping front and rear wheels over before ruling out balance issues. It is not unknown for mistakes to be made. Speed related problems are most commonly wheel/tyre balance related.
Swivel preload, condition of all steering joints, and steering damper would be next on the list to check, together with all front axle suspension bushes. Also check wheel-bearings.
Post #724411 20th Aug 2018 5:13pm
JOW240725
Wheels were all rebalanced by a company I know normally get it right. They also rotated the wheels so pretty sure it isn't wheel related. Thanks, I'll add the suggestions to the list.
Would it be a good excuse to upgrade to the Disco 2 drop arm with sumo bars from Gwyn Lewis? James
Post #724423 20th Aug 2018 5:41pm
CarMan
I think it's those awful 16" Bowlers, so why don't you sell them to me as you want the 18's anyway Whistle Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #724425 20th Aug 2018 5:44pm
zsd-puma
It's still possible to balance buckled wheels and misshapen tyres. They'll say they're ok on the balancing machine but be terrible at certain speeds on the road.
It's usually visually apparent when you spin the wheel.
Post #724431 20th Aug 2018 5:50pm
pme
United Kingdom 2007 Defender 90 Puma 2.4 SW Tonga Green
I recall land rover user guide saying NOT to rotate the wheels, something related to crap geometry quality resulting in a specific wear pattern on each corner. I wait to be corrected.
I had something very similar and it was down to a new tyre fitted as the old one was damaged. Michelin latitude cross, took about 500 miles to settle in.
Post #724444 20th Aug 2018 6:28pm
Check your panhard rod bushes and bolts, as well as your steering damper and tie rod.
Post #724455 20th Aug 2018 7:16pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
All the owner manuals I have had in the past 40 years have had the wording similar to " Do not swap to tyre's round" .
even the workshop manuals say this, the service check sheets have wording similar to " Note the position of each wheel when removing and re attach in the same position".
I remember taking a Disco in to a dealers for service and I watched a mechanic/fitter marking the tyres with chalk and then putting metal paint marker on the studs against the chalk mark.
Now my Indy tells me he swaps the wheels diagonally to get the best wear from the tyres as the front wear off the tread on the inside. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #724530 21st Aug 2018 9:25am
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I had the same problem, funnily enough straight after I put my Bowlers on.
They were balanced pretty badly and had that sorted out but the issue remained. In the end I found that the preload on the swivels was way out (way too loose), one side in particular being very bad. I did the one side and that has pretty much sorted it although I do get a bit of a wobble at around 70 if the road surface is not great. I just need to find time to do the other side.....
It’s easy enough to check by removing the steering joints. I had a spring balance to hand but it was so obvious mine were out as there was virtually no resistance at all
Post #724533 21st Aug 2018 9:54am
JOW240725
Bowlers have been great up to now and rebalancing/rotating tyres have made no difference to the wobble so pretty sure (but not certain) it's not wheel related. To be fair it isn't bad, I'd not really noticed it, but SWMBO (the daily driver) is insistent something isn't quite right. Last time I ignored her complaint the output shaft went 2 days later Embarassed Shocked
It's being looked on Thursday night, so we'll see. Thanks for all the suggestions! Thumbs Up James
Post #724558 21st Aug 2018 11:54am
zsd-puma
Sounds like hard work, why not just write FL, FR, RL, RR on the tyres in chalk then wash it off afterwards. Laughing
Post #724570 21st Aug 2018 12:51pm
