![]() | Home > Puma (Tdci) > Welding on a TDCi what do I disconnect? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Just pull the negative (earth) lead from the battery.
![]() Wanted, Forward Control Anything considered. |
Following the handbook instructions to disarm the BBUS first, if you have one fitted. Darren
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 ![]() ![]() ![]() |
I don't think Ozzie spec Defenders had that.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20755 ![]() ![]() |
As well as the negative, take the positive off too and check all switches are off.
You should then be good to go. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Why? ^^ 80" 80" 86" 88" 90"
Just completely isolates everything that way.
Depends on what type of welding in question as well. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
Key for safe welding is good ground connection close to the welding point and on the welded part. This will minimize current leakage through rest of the car. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
